Author Topic: Auto choke on pearburge carb help  (Read 1417 times)
Offline stainesy
« on: 13 November 2012, 22:12 »
Ok here goes. My jetta 1.6 has the pearburge carb with auto choke.
It seems as if the choke is stuck open as its constantly revving like it is.
Is there a way to bypass or remove the auto choke and still use the carb as normal?
Offline clipperjay
Re: Auto choke on pearburge carb help
« Reply #1 on: 14 November 2012, 09:09 »
The choke unit is controlled via waxstat you might want to remove it out and replace it the idea is a metal plunger moves in and out affecting the choke whne the engine is cold or hot if the waxstat is stuck in cold position the choke will not adjust itself and still thinks its cold hence over reving at idle.
I would look for Webber carb conversion then you can change over the whole set up for a more reliable manual choke system.
Offline stainesy
« Reply #2 on: 14 November 2012, 14:40 »
Cheers. It now seems fine today. It's back to normal.
Yeah my plan is to get a weber when I get the cash.
