Golf mk4
Wazzzer
problem with speedo :s
Topic: problem with speedo :s (Read 790 times)
simon_709
GTI forum regular
12 November 2012, 18:08 »
Hi guys, I got in my golf after work to notice the speedo needle had dropped from the 0 to the corner of the mileage screen, when I drove it the speedo worked fine but it was obv reading a lot lower than it should because its starting at a lower point, haven't herd of this problem before but I'm hoping someone else has so they can tell me what to do
thanks
My Golf GTi, RS4 reps 17", coilovers, tinted windows, De-cat and middle box removed with 3" oval back box, stage 1 Revo re map, G60 flywheel/VR6 clutch, HID kit, Forge 007p,
rio_gti
"i'm not spending any money on it" Got a Hybrid!
Re: problem with speedo :s
12 November 2012, 19:14 »
get it onto vagcom and test the display, see if it spins as far, but then i think also you can change it with vagcom
2000 GTI 1.8t ARZ, S2000 filter, DSG intake, Forge 007 dv, Catch can, R-tech custom remap, 3" Supersize Silicone TIP, Powerflex dog bone, 'The Beast' FMIC, Ultimate delete, LCR fuel pump, 3" Turbo back, K03 hybrid, Ported Manifold, S3 injectors, 80mm maf = 280bhp 270lbft
simon_709
GTI forum regular
12 November 2012, 21:15 »
Ok then will get it plugged in. Really weird lol
Ashmond
Money, b!tches And Boost
14 November 2012, 17:23 »
might be a problem with your speedo sensor that sits on top of the gearbox?
simon_709
GTI forum regular
14 November 2012, 23:25 »
Yeah? Maybe ill take it apart and put it back together and see what happens.
Golf mk4
Wazzzer
