Author Topic: 16v on normal unleaded or super unleaded?  (Read 2179 times)
Offline Foreveryoungaus16v
« on: 12 November 2012, 17:46 »
Hi, whats ur opinions?
163 BHP (TSR POWER RUN)
Offline dragongreengolfgti
  • my golf gti mk3
Re: 16v on normal unleaded or super unleaded?
« Reply #1 on: 12 November 2012, 17:53 »
been running mine on super unleaded for last 6 months and i get about an extra 40 miles out of it i will not go back to 95 now even if super leaded helps or not  :smiley: oh and got 161 bhp on dyno yesterday so i think it does a little  :smiley:
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 12 November 2012, 18:09 »
if i run mine on normal 95, my car pinks going uphill. So i stick with super & it feels different (power wise)
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline tweed
« Reply #3 on: 12 November 2012, 18:11 »
You've probably got the extra miles from the air temperature decrease.
Shell v maxx super unleaded will give you 3/5bhp over a basic supermarket normal unleaded.
Is it worth the extra pennies on a daily? no not at all.
Does it make your engine run better? No again.
Its a way of getting more money out of us punters  :rolleyes:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 12 November 2012, 20:39 »
Generally i run mine on standard unleaded due to being a tight b@stard but every few tank fulls i like to stick some Tesco momentum (99 ron) in and it definitely runs smoother and quieter. If i don't do this i start to get the occasional pinking under load due to the advanced timing set up that came with the ECU chip I run.
Offline Len
« Reply #5 on: 12 November 2012, 20:52 »
Have only ever used 95 RON and no problems for nearly 9 years and 50,000 miles.
Think that says it all.
www.sas.org.uk
www.the-ace.org.uk
Offline Screech16v
  • MK3 20vt AGU
« Reply #6 on: 12 November 2012, 20:56 »
This is me also,including the tight b@stard bit  :grin:
« Reply #7 on: 12 November 2012, 22:19 »
Normal will be fine.
Offline Bellend
« Reply #8 on: 12 November 2012, 23:50 »
Cars use slightly more fuel in the winter.
Cold air = more oxygen = more fuel needed to compensate.
Makes the car quicker too.
Where all my moneys went.
