Author Topic: sunroof to door drains and wet carpet SOLVED!!!  (Read 1207 times)
Offline GTi_James
« on: 12 November 2012, 16:42 »
right, had enough of the leaking little sh!theads so decided to solve this once and for all. for about 4 hours i had all my doors in pieces looking for water marks and the like. then i had a light bulb moment.
got a litre of water and poured it through the sunroof drains and waited eagerly to see where the water would come out of, both door nipples stayed bone dry and i noticed a dark patch spreading through the carpet  :lipsrsealed: so i grabbed my side cutters and cut, yes thats right, i cut the crimped part of the drain nipples off. end result, two gapping wholes, my reasoning being that water will no longer be stopped by those stupid little slits, 2 litres of water later and nothing still, i bit the bullet and yanked off the nipples, woah and behold i found the water...or whats left of it, the pipe had been PUSHED OUT of the grommet with all the years of rain and dust and the pressure just caused it all to happen, and as there isnt any seal with the interior panels and interior carpet, its leaks everywhere!
the grommet fits over a riged plastic tube in the door pillar as most of you are aware. a bit of a b!tch to pull out...because it doesnt  :lipsrsealed: so there i was, i'd clear up the crap in the gromet and i can see straight through without any obstruction.
another 5 hours, i decided to seal the doors up again as i thought about this and then my old man walks up with his cup of black and about 2 meters of washing line in his hands, hands me it and says, lube up your nipples  :lipsrsealed: and feed this through the drains  :rolleyes:
so pushed the wire down the drains in the sunroof, a whole lot of gunk came down with it, pulled it through the grommet and tide a MASSIVE knot in the end. lined it all up as best as possible and gave it a good tug  :whistle: worked a blinding treat, felt the inner drain pipe pop into place in the gromet and everything slipped nicely on with some good old vascelene!
5 litres of water and boom! the water is on the outside of the car! and as for the puddles in the car i i placed a safety heater and dehumidifier into the boot with out any seats in, left it over night and 5 ltrs of dirty water has been extracted, doing the same again to night and over the weekend!!!
anyone having this problems should look into this, sorry i didnt manage to get pics but i finaly cracked this at about half 5 and the sun was gone  :cry:
try this at your own peril though!
« Last Edit: 12 November 2012, 19:43 by GTi_James »
Offline rio_gti
Re: sunroof to door drains and wet carpet SOLVED!!!
« Reply #1 on: 12 November 2012, 17:12 »
good work!!!
worth putting this in the maintinance section i think  :wink:
Offline GTi_James
« Reply #2 on: 12 November 2012, 17:16 »
 :grin: I was thinking that but wanted ppl to see what I wrote n try it out before that
« Last Edit: 12 November 2012, 17:30 by GTi_James »
Offline Harooshum
« Reply #3 on: 02 September 2013, 14:25 »
Hi GTi_James, any chance of some pics then?
Offline GTi_James
« Reply #4 on: 02 September 2013, 14:34 »
errrrr could try fella but no promises tbh as i'm busy this whole week. may be able to get something on saturday this week
