Author Topic: Got new bike, again! Pg 11/12  (Read 51754 times)
Offline golf-sib
  • Турботазик
Re: Got my bike! Any tips and advice?
« Reply #20 on: 14 November 2012, 09:26 »
Cheers, I live next door to train station so its not a problem. My concern is how do I judge when roads are unsafe to go out on and when they are considered fine again.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline ade1703
« Reply #21 on: 14 November 2012, 21:06 »
Look at the weather forecast, look at the conditions outside, see if there is any frost on the cars?
Think about the road you will be using, is it an A road with lots of overhanging trees that could prevent the road from getting any Sun to thaw it.
I found last year a couple of times I was out that the roads hadn't defrosted enough and were incredibly slippy. Stay off the white lines!
The clutch will come with practice, when I took my DAS I had real issues getting 1st gear on their bike but since I passed its just got easier and easier.
Best advice is just to take it easy
Offline spikenipple
« Reply #22 on: 17 November 2012, 11:13 »
There are a million tips for riding a bike safely and especially through winter, but the biggest lifesaver for me has been to regard everyone else on the road as a retard.
Learning how to interpret other vehicle's 'body language' is a priceless skill to keep it rubber side down.
A few other important things:
Always maintain a decent distance between you and the vehicle in front - imagine they will slam their brakes on at any moment, and give yourself enough distance to react and stop yourself safely.
When riding in the wet/cold, apply BOTH brakes progressively, don't ever snatch at the brake or you'll lose the front end and go down like a sack of potatoes!
If you find yourself going into a corner too hot then look at the point where you want to go and lean smoothly into it; don't slam the brakes on as you'll stand the bike up and carry on in a straight line into the nearest telegraph pole/oncoming car/kerb/armco etc. Target fixation is surprisingly easy to fall victim to so always keep your eye on where you want to go. You'll get away with gently applying the rear brake round a corner - you want maximum grip from the front wheel.
As for maintenance, the biggest issue you'll find during the winter is your chain getting covered in crap. Keep it clean and lubed up. To protect the exposed parts of the bike from salt etc, get a can of ACF50 and apply it with a cloth, obviously keep it away from the brakes :grin:
Happy biking :cool:
Offline Ant1981
  • Feed me, prod me
« Reply #23 on: 17 November 2012, 15:33 »
Yeah, I've got a tip for you....
.....do f**king do what I did to mine this year....
 :whistle:
'09 Kawasaki Ninja ZX-6R
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #24 on: 17 November 2012, 16:07 »
Same, I binned mine for the sake of taking my time and getting to work 5 mins late
Offline golf-sib
  • Турботазик
« Reply #25 on: 17 November 2012, 22:34 »
Happy biking :cool:
Thanks for alot of the tips, they are priceless, I already had to slam my rear brake once and end up like a sack of potatoes  :whistle: :whistle: :whistle: At least there was no damage to no one nor to the bike except a clutch lever luckily and a good gap. But I rather get tips than learn the hard way by learning myself
Also Ant wtf did you do?
1.8T AGU..
R135
  24
Offline tshirt2k
  • Been there...Done that...
« Reply #26 on: 18 November 2012, 09:40 »
As mentioned, use both brakes progressively. The rear brake alone won't slow you down. In bad weather everything gas to be smooth. Acceleration, braking etc. This is the worst kind of weather to ride in as it's not wet or dry and its frosty and leaves are in the ground.
Some good advice here. You DO have to expect someone will pull out on you. Try to look in the eyes of drivers at junctions to make sure they notice you. Also, if you're not sure they've seen you. Don't be scared to bip the horn.
Check tyre pressure regularly. They are wry important on a bike. More so than a car as they are the only thing between you and the ground. Also get the best tyres you can afford. Stickier will give you more confidence cornering, but have less mileage.
The test doesn't really prepare you that well for the roads, you will start learning now you're OB the road on your own.
Good luck. Don't be a hero. Cars and trucks are alot stronger than us.
Mk3 ABF 16VT Megasquirt V3
Offline JC
  • Back in the North.
« Reply #27 on: 18 November 2012, 09:50 »
Trial and error is the only way.
every journey will be an experience, even for regular commuters. Hidden damp patches in shaded areas, roadkill mud on the road, etc etc etc
I have ridden in a heavy snow storm without issues as it wasnt sticking, people thought I was crazy. visibility was my only issue but I was getting home - no way was I getting snowed in at work - and as I was commuting 120 miles a day on a bike for 9 months on roads a knew well, could i say the roads were going to be safe for the return journey, not a chance - its another RISK factor of biking, and one I have stopped taking 8 years ago.  :whistle:
Offline Ant1981
  • Feed me, prod me
« Reply #28 on: 18 November 2012, 15:58 »
Came off on a roundabout. Had a new front tyre which are a bit slippery when new. Wasn't paying attention to the fact that I was on a new tyre, so the bike slid until the entire side hit a kerb.
Offline golfyste
  • Project track car
« Reply #29 on: 18 November 2012, 21:34 »
A tip for stopping the fogging on lenses etc
get a bar of soap and rub it on your visor and then leave 2 min and buff it off.
I do this on my off road goggle and it works.
and trust me they normally fog up 10x worse then a normal visor!
