Author Topic: why does it keep wheel-spinning?!  (Read 3955 times)
Offline vw_golf_nutter
« on: 11 November 2012, 16:33 »
i have a 2.0 manual cabriolet and its always wheel spinning in 1st and 2nd. Now im no boy racer and dont drive it hard at all. its really annoying because i pull out of a junction and people look at me like im a wreckless driver! Is it just a case of better tyres? The treads are ok on these at the minute.
Offline tweed
Re: why does it keep wheel-spinning?!
« Reply #1 on: 11 November 2012, 16:43 »
its this simple. The temperature has dropped making your tyres hard and no grip.
I recommend continental winter tyres.
Offline tweed
« Reply #2 on: 11 November 2012, 16:46 »
oh and by the way if its wheel spinning in 1st and 2nd, lift your foot on the pedal. Be gentle with it.
really important also is tyre pressure. What is yours?
« Last Edit: 11 November 2012, 17:23 by tweed »
Offline leigh_harty
  • Audi AGU
« Reply #3 on: 11 November 2012, 19:04 »
What tyres are you running?
Dont lose your dinosaur!
« Reply #4 on: 17 November 2012, 21:49 »
they are pirelli p6000's, except i have one on the back which is avon, but dont seem to be gripping very well. i have a few junctions where i live that are steep hill starts and it really doesnt like them! you reckon continentals then? pressures on 38.
Offline leigh_harty
  • Audi AGU
« Reply #5 on: 17 November 2012, 21:53 »
Never had continentals. Currently got firestones and I highly rate them as a wet tyre.
Even with the hefty vr lump they do well. Maybe you could benefit with clutch control to prevent spinning?
Offline tweed
« Reply #6 on: 17 November 2012, 23:24 »
Had them tyres on my 16v and hated them. Wheel span really easy, under steered a lot. Only had two so swapped them round and put them on the back. Obviously over steered a lot but much better to control. I put them to 29psi. I ended up binning them with plenty of tread and got toyo tr1r's
Maybe get them if they are cheaper.
Offline Khare
  • The bear that khares
« Reply #7 on: 17 November 2012, 23:26 »
I used p6000's and found them very bad, especially in the wet. 38 is fine for the front, use 34 on the back. However try lowering the pressures from 38/34 to 34/32. If it helps report back.
Offline dom
  • Back in a Mk4
« Reply #8 on: 17 November 2012, 23:41 »
I also ran P6000's briefly and found them to be awful.
Without wishing to be offensive, you might need to work on your pedal control. Regardless of tyre brand you should be able to do a wet hill start without spinning up, especially in 2nd gear.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #9 on: 18 November 2012, 00:02 »
Although I know wheelspin isn't something you want your car to actually do i've found my valver probably the hardest car to get spinning out of nearly all the cars i've owned which is odd considering it's got at least the stock 150bhp?! ...I think something could be wrong somewhere tbh.  :undecided:
