Author Topic: GTI headlights  (Read 1650 times)
Offline akz786
GTI headlights
« on: 16 July 2005, 18:54 »
got some FK angel eyes, thought its would be easy to replace originals, apparently you gota remove the whole bumper! WTF! is this true? there seems to be more screws at the bottom of the light. If this is true can i do this myself?
TIA
Offline S11EPS
  • No golfs here. Only a C63 mercedes
Re: GTI headlights
« Reply #1 on: 16 July 2005, 19:21 »
aye mate, tis true, the bumper needs to be removed in order to get the headlights out.
However, its not as hard as it sounds. 4 screws in each wheel arch, a couple of bolts on the bottom of the bumper (behind the towing eye cover, and the same spot on the other side of the bumper) unclip the grill and remove another 3 or four bolts, the just slide the bumper off.
Before taking the bumper too far from the car, unclip the temperature sensor in the bottom corner.
Easy peasy. You'll have the bumper off, new lights in and bumper back on in an hour or so.
The greatest leveller of them all - the Carousel
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
Re: GTI headlights
« Reply #2 on: 19 July 2005, 19:13 »
Easy mate, done in about 45 mins if your clued up.  Check out this guide with picshttp://home.nycap.rr.com/brandonc/headlight/ :wink: :wink: :wink: :wink:
