Author Topic: will it fit ???  (Read 1332 times)
Offline theviper
will it fit ???
« on: 16 July 2005, 16:29 »
dose anyone know it the shock's from a 1988 golf will fit a 1990 golf as i know there are some bits will not fit
thank's pete :evil:
Hatchet Harry
Re: will it fit ???
« Reply #1 on: 16 July 2005, 17:18 »
good question! they should do, id lay the parts out side by side to double check though...
Offline Mr Blue
Re: will it fit ???
« Reply #2 on: 16 July 2005, 17:20 »
i havnt noticed any change in the suspension setup on early or late mk2's. i think the spring / shock ratings are diffrent from 8 to 16v's and thats about it :rolleyes:
Offline workhorse '90 8v
Re: will it fit ???
« Reply #3 on: 16 July 2005, 18:40 »
1990+ gti's the front shock is the strut. I thought it wasn't b4 1990, but never worked on a pre 90 so can't verify this.  Think rear shox are the same tho..
Offline Gambit
Re: will it fit ???
« Reply #4 on: 18 July 2005, 09:00 »
its a straight swap
90 spec cars used fully enclosed front shocks while pre 90's had shock inserts. both use the same fitment though!
