Author Topic: KEY STUCK IN IGNITION :(  (Read 2127 times)
Offline james2
  • No scammers please.
« on: 10 November 2012, 17:57 »
LOL whys this happing i cant leave it like this ,someone will rob it ?
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: KEY STUCK IN IGNITION :(
« Reply #1 on: 10 November 2012, 17:58 »
What?
You drove somewhere, then turned it off and went to remove and it won't let you? Try turning it back on and remove again?
Offline james2
« Reply #2 on: 10 November 2012, 18:00 »
yeah its locked in the ignition  :undecided:
Offline james2
« Reply #3 on: 10 November 2012, 18:06 »
its like when you turn the ignition on you cant pull the key out ,that what its like.
Offline Ant1981
  • Feed me, prod me
« Reply #4 on: 10 November 2012, 18:20 »
It's not a yank import is it that won't let you take the key out unless the gear is in neutral or something?
'09 Kawasaki Ninja ZX-6R
Offline JC
  • Back in the North.
« Reply #5 on: 10 November 2012, 18:22 »
 basics time, has the key turned fully back in the barrel ? to the off position ?
Offline GTi_James
« Reply #6 on: 10 November 2012, 19:02 »
+1, i felt like a prune when this happened and it was because it wasnt all the way back in the ignition
Offline james2
« Reply #7 on: 11 November 2012, 23:11 »
how you know. But it was in park . I gave use the key back after 2 hours .  :evil:
Offline james2
« Reply #8 on: 11 November 2012, 23:12 »
how you edit post . It was in park .
Offline james2
« Reply #9 on: 11 November 2012, 23:13 »
god : It gave use the key back after 2 hours
