Author Topic: Which turbo is on my turbo.  (Read 1267 times)
Offline james1981
« on: 10 November 2012, 17:34 »
I have taken my turbo of because i was loosing oil somewhere, there was a lot of oil just behind the impeller for the intake(there was loads of oil just behind the housing the impeller came off with the housing if you get what i mean) is this suppose to be like this. Also here is the part num of the turbo that was on, KO3 026CF5018918 AND ALSO A NUM ON THE HOUSING WHICH IS 53041015066, is this the ko3s(if thats what it is called) and not the standard ko3. thanks for help in advance.
Offline james2
  • No scammers please.
Re: Which turbo is on my turbo.
« Reply #1 on: 10 November 2012, 17:40 »
what engine have you got AGU AUM and does your car smoke
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline james1981
« Reply #2 on: 10 November 2012, 17:49 »
Its the ARZ engine some white smoke in a morning, on cold start quite a bit sometimes. ill take  pic hang on 6 mins.
Offline james1981
« Reply #3 on: 10 November 2012, 17:59 »
how do you put pics on lol.
Offline james1981
« Reply #4 on: 10 November 2012, 18:23 »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 11 November 2012, 03:23 »
K03-026 is the K03, not the K03s
