Author Topic: Which injectors?  (Read 1328 times)
Offline Ajd12
Which injectors?
« on: 10 November 2012, 11:07 »
Hi, I'm trying to restore a mk2 8v gti that's been stuck in a garage for 16 years. The injectors have been tested and found to be knackered, does anyone know what injectors will fit? Struggling to find ones for a gti. It's a 1986 model with k jet.
Offline Gambit
Re: Which injectors?
« Reply #1 on: 10 November 2012, 11:16 »
You need bosch kjet injectors. Just look for your local bosch distributor they will be able to order them up for you
Offline Ajd12
« Reply #2 on: 10 November 2012, 11:25 »
Thanks a lot, and they're all the same? When I called asking for gti ones they said they'd been discontinued
Offline Gambit
« Reply #3 on: 10 November 2012, 12:05 »
Who did you call? Vw? Bosch distributor should still be able to get them or else stick a wanted ad up and you can get a set of 2nd hand ones just to get you on the road
they aint cheap new, like about 25-30each
Offline Ajd12
« Reply #4 on: 10 November 2012, 12:25 »
Yeah I tried vw and they were no use. I'll try Bosch then, thanks for your help  :smiley:
