Author Topic: Heated seat loom install issue  (Read 1610 times)
Offline Shady Pioneer
  • graphic designer.
« on: 10 November 2012, 03:19 »
I bought a heated seat loom which included a brown, grey, green, white and 2 black plugs. I've connected the brown plug to the plug cluster just above the fuse box. The grey and green plugs are plugged into a cluster block just above the fuse box too (behind the steering wheel to the right).
I've read that the green provides power and grey is the illumination for the switch. Problem is once all plugged in it doesn't seem to work, anyone got any ideas?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
  • graphic designer.
Re: Heated seat loom install issue
« Reply #2 on: 10 November 2012, 11:57 »
Thanks for that mate. I've checked the relays and they are clicking, although the seats don't seem to be heating up and the switch does illuminate when on.
What to do?
Offline JC
  • Back in the North.
« Reply #3 on: 10 November 2012, 18:26 »
get someone more technically minded to look at if for you  :whistle:
 :kiss:
VW BUSH
« Reply #4 on: 10 November 2012, 18:52 »
 :kiss:
Ask your misses
Offline JC
« Reply #5 on: 10 November 2012, 18:55 »
 :kiss:
Ask your misses
Mine or his  :huh:
