Author Topic: Fault code 16514 advise needed  (Read 11004 times)
Offline Chris#101
« on: 09 November 2012, 18:06 »
Howdo. Ive recently been getting the following fault code come up;
16514/P0130/000304 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
Possible Causes
Oxygen (Lambda) Sensor Heating Bank 1 Sensor 1 faulty
Possible Solutions
Check Oxygen (Lambda) Sensor Heating Bank 1 Sensor 1
Ive deleted it a few times and it keeps popping up with the enginge managemnt light ontop of terrible fuel consumption :undecided:
is there a way of testing a lambda sensor? or as a general if there shot there shot!? as at around  £100 a go and  being an apprentice its fair bit of wedge if its not going to fix it.
anyone advise ? :smiley:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline NegoGti
Re: Fault code 16514 advise needed
« Reply #1 on: 09 November 2012, 18:20 »
hy mate ive had the same problem no chance to fix the sensor  :sad: and a new one its 130£ from vw  ive had one before from eurocarparts the bosch one it last just 2 months for me but this one frome vw comes with 2 year guarante
Offline Chris#101
« Reply #2 on: 10 November 2012, 10:44 »
Also am I right in thinking that this code is for the lamda sensor precat?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 10 November 2012, 12:20 »
Could also be wiring to the sensor. I'm pretty sure B1 is the pre cat
Offline pickles
  • Next!!!
« Reply #4 on: 11 November 2012, 10:39 »
i had this code when i decated, could it be a leak somewr
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline Chris#101
« Reply #5 on: 11 November 2012, 11:25 »
I always used to get fault code 16804 when I fitted my 3" turbo back decat no res exhaust. but since having it remapped by R-tech they got rid of the code for good. but the new 16514 code has only recently been coming up. I might take a look under the car today and see if theres anything obvious.
If not do you think a new sensor will get rid of the code?
Offline AaronGS
« Reply #6 on: 11 November 2012, 13:46 »
Faulty pre-cat sensor, its wiring or more likely an air leak between the MAF and the lambda.
Mind you, that code is pretty specific to the sensor itself.
i may have an old, working sensor if you need you.
Offline mar_k
« Reply #7 on: 11 November 2012, 15:46 »
The B1 doesn't mean anything other than its Bank1, But since these are only 4 cylinder cars they only have 1 Bank.
Only a 'V' engine would have a B1 and B2 code which tells you which bank of cylinders has the fault.
Its the S1 and S2  ( sensor1, sensor2 ) that tells you weather its pre cat or post cat, S1 is pre cat and S2 is post cat
« Last Edit: 11 November 2012, 15:52 by mar_k »
Offline AaronGS
« Reply #8 on: 11 November 2012, 15:50 »
The B1 doesn't seem to mean anything other than its a 4 cylinder car,
Only a 'V' engine would have a B1 and B2 code which tells you which bank of cyclinders has the fault.
Very, very true. But in this case its B1, S1. So it is the pre-cat sensor that is being flagged up. But yes, its S1 that tells you that! Good point.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 11 November 2012, 19:08 »
Ah there you go, got mixed up with B's and S's lol
