Author Topic: mk2 gti 8v 90spec conversion  (Read 1882 times)
Offline steelcityboy
« on: 09 November 2012, 17:57 »
hi there people , got myself a h reg mk2gti 8v on a webber carb love driving it but want some more power :laugh: i want to go 2litre abf but have a few question ( not the brightest spark lol) i can get my hands on a mk3 abf for a cheap decent price what other parts do i need ? and i want rid of the carb and want to go injection is this easy to do and could i use the one off the abf ? also would like to add my car is not a orginal mk2gti 8v it was a 1.3rabbit and was converted to a 1.8 8v!!( i didnt do the conversion) ?let me no please!!! :smiley:
Offline Jimmyrallye
  • 20vt goodness
Re: mk2 gti 8v 90spec conversion
« Reply #1 on: 09 November 2012, 18:24 »
Everything just bolts straight in i done a mk3 gti abf gearbox conversion on my mk2 20vt the other weekend and it wos a good days work with no problems .. All mounts are the same just be wireing but i payed some one to do that on my engine
Offline Dogbot
« Reply #2 on: 09 November 2012, 18:35 »
Couple of choices to make firstly dude,
Do you want to keep the mk2 clocks, or fit the mk3?
Mk3 coil or mk2?
Do you want the abf gearbox or the 8v one?
(means either seat cable conversion or hydro pedal box conversion is required. Both pretty easy to do tho)
Do you want to go widetrack?
The conversion is largely plug and play, you can make it as hard or as easy as you like, trouble your going to have is how well the original conversion to 8v was done,
If your gonna get a whole car it's by far the easiest an most cost effective way to do it, there's so much on the Internet about this conversion it's very simple to do, the hardest thing is not getting confused with conflicting build threads and posts.
Good luck dude!!
Parts you'll need as a start till you answer the above questions
Engine bay loom
Ecu & correct ecu relay
Immobiliser box and transponder ring, with key chip
Engine of course,
Mk3 downpipe & manifold
Mk3 decat section
Mk3 tank with In tank lift pump
(have heard you can get away with the 8v item but why introduce aggro for yourself)
Mk3 fuel pump wiring
That's about all I can think of without the answers from them above
« Reply #3 on: 09 November 2012, 23:03 »
Thanks dogbot would like to keep mk2 clocks as for coil pack which ever ones more realiable , and what's the difference between wide track and short ( sorry for sounding like a spanner!) Gearbox I dnt really mind that agsain which ever gonna b more realiabe I would say the 8v conversion was done ok ish could have bin better but was good enough well the mk3 abf I can get is from a family friend and only wants 300 quid off me so just really wana no wht other parts I'd need nd the difficult parts of the conversion. Thanks pal
« Reply #4 on: 10 November 2012, 03:37 »
uote author=Dogbot link=topic=243849.msg2241846#msg2241846 date=1352486104]
Mk3 coil or mk2?
Good luck dude!!
Engine bay loom
Engine of course,
Mk3 decat section
[/quote]
Offline Dogbot
« Reply #5 on: 11 November 2012, 10:37 »
Worth doing some searches dude, to use mk2 clocks you'll wanna use the mk2 coil and widetrack is mk3 front subframe and wishbones as they are wider
