Author Topic: boost valve  (Read 938 times)
Offline djmagpie
boost valve
« on: 07 November 2012, 23:41 »
had a old boost valve laying about so decided to put it on car gose like a rocket got it running just under 1 bar ,wat damage can this do to my engine ?? not really worried abot turbo damage as its a k03 and some time soon ill be replaceing it .
1.8t agu,,Bora Vents,,Cai,,Vr6 clutch/G60 flywheel,,forge dump valve,,jom coilovers,,eibach front and rear arbs,, 15mm front 20mm rear spacers ,,3" downpipe & decat..sportex 4"oval exhaust
Offline EsSeX dAn
Re: boost valve
« Reply #1 on: 08 November 2012, 17:57 »
out of interest where did you mount it? as for damage youll probably bust the turbo before anything else goes
i think i love you.....
Offline topher
  • Administrator
  • fully functioning
Re: boost valve
« Reply #2 on: 08 November 2012, 19:02 »
anything under 1 bar seems to work "okay". not ideal or the most efficient way to extract more power from the engine but as long as there's enough fuel when on boost then AGUs dont seem to complain too much.
Offline Prawny
  • R-tech power!!!
Re: boost valve
« Reply #3 on: 08 November 2012, 20:00 »
it's novel at first when you're just flooring it, but after a few days of driving it a bit more normally you'll soon realise that it'll be driving like an absolute sack of turd, and you'll remove the valve and wait until you can afford a remap :)
Offline davemk4
Re: boost valve
« Reply #4 on: 10 November 2012, 19:28 »
I fitted one to my 1.8 turbo audi and drove it went like the stink but went into limp mode sometime and in 1 drive made the turbo glow very orange took it straight off and mapped it. Then it drove great
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
