Author Topic: Any tiling experts here?  (Read 1951 times)
Offline bobbarley
  • I'm kind of a big deal...
« on: 07 November 2012, 20:29 »
I've bought tiles to do our bathroom and have a bit of a quandary which I'm hoping someone can help out with.
We have two typs of tiles.  10x20cm and 10x10cm tiles.  The idea being to work out some random kinda pattern as we go along.
Originally I worked out that obviously two 10x10cm tiles is the same as one 10x20cm tile.  Then I realised it isn't.  There's a 2mm spacer to go between before it get grouted later on.  So when we use two 10x10cm tiles, it'll actually be 20.2cm wide.  Over the course of an entire wall that's really going to be noticeable. The lines won't run true down the wall.
Has anyone done some tiling and have a solution?
VW BUSH
Re: Any tiling experts here?
« Reply #1 on: 07 November 2012, 20:50 »
Factor in the run out on your walls and the variation between tile size through the pack and pack to pack and you have a fecking nightmare :grin:
Offline JC
  • Back in the North.
« Reply #2 on: 07 November 2012, 21:07 »
Simple Answer - take one kind back - they ain't every going to match  :whistle:
Offline Toby
  • Car - less
« Reply #3 on: 07 November 2012, 21:19 »
Yea!! They will be a bastard!! Due to having grout lines 2mm - 10x10 = 22mm  :whistle:
Currently down under
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #4 on: 07 November 2012, 21:25 »
Carefully cut 10cm off the 10x20's they will then fit, job sorted :cool:
Thom
Offline Toby
  • Car - less
« Reply #5 on: 07 November 2012, 21:32 »
Feature wall. Lay the 10x20 horazontle done
Offline kempie
  • where would we be without duct tape?
« Reply #6 on: 10 November 2012, 10:36 »
smash them all up then stick all the bits to the wall in a mosaic (spelling) like type thingy
Offline Ant1981
  • Feed me, prod me
« Reply #7 on: 10 November 2012, 12:28 »
Thom
That'd look sh!t, you'd see the sharp edges rather than the soft glazed edges of a tile that's actually that size.
'09 Kawasaki Ninja ZX-6R
Offline bobbarley
« Reply #8 on: 10 November 2012, 14:13 »
I took the coloured ones back and am just going to do the entire wall in white  :grin:
VW BUSH
« Reply #9 on: 11 November 2012, 18:12 »
Don't use a white grout its a b!tch to keep clean :lipsrsealed:
