Author Topic: flat battery  (Read 1069 times)
Offline dhorsfall2000
flat battery
« on: 06 November 2012, 18:24 »
hi, my battery keeps going flat, but only when its really cold outside  :sad:
anyone come across this before, dont wanna buy another battery if its not that lol
thanks
Offline Tezmax
Re: flat battery
« Reply #1 on: 06 November 2012, 18:34 »
pretty much standard on any car, once you hit winter with cold mornings you find your
battery is just not good enough anymore.
If your alternator is fine, then new battery time.
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline Hoggy
  • Mk4 GT TDI 150.
Re: flat battery
« Reply #2 on: 06 November 2012, 22:23 »
Mine was flat after my holiday, charged her up, seemed ok for a couple of week, temperature dropped below 0°C and it collapaed.
As said above, pretty standard thing.
If in doubt, get it tested.
Offline Ant1981
  • Feed me, prod me
Re: flat battery
« Reply #3 on: 06 November 2012, 22:26 »
It's not really a standard thing unless your battery isn't well kept.
Short journeys will do this as the altenator/charging circuit can't put enough charge in, as the charging rate is very slow aswel as power being used by the car at the same time, so your battery will never be fully charged - unlike plugging it into a proper charger which will have a deeper charge rate.
'09 Kawasaki Ninja ZX-6R
Re: flat battery
« Reply #4 on: 14 November 2012, 20:45 »
the alternator output is too high
Offline james2
  • No scammers please.
Re: flat battery
« Reply #5 on: 14 November 2012, 21:26 »
get a new battery = sorted  :wink:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline km
Re: flat battery
« Reply #6 on: 14 November 2012, 23:29 »
motor factors replaced my battery under warranty last week :kiss:
