Author Topic: fuel pipe replacement.  (Read 789 times)
Offline km
« on: 05 November 2012, 23:52 »
my mate broke off the clip on hose number 1, on the filter side.
if i order this part, is it as simple as pulling it out and feeding it through again?
thanks.
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
Re: fuel pipe replacement.
« Reply #1 on: 06 November 2012, 02:09 »
Never replaced one but shouldn't be too bad a job
Offline Gabriel2202
« Reply #2 on: 06 November 2012, 08:39 »
thanks.
I did this a few months ago, those clips are a pain! you have to undo the tank straps and drop the fuel tank an inch or the clips on the hose won't fit through the gap.... not too bad though if you have a jack and some axle stands  :smiley:
Golf IV 1.8T AUM
Golf V GT TDI PD170
Offline Gabriel2202
« Reply #3 on: 06 November 2012, 08:44 »
Also to make it easier, tie some string to the the old pipe where it clips onto the fuel pump sender and pull the pipe out from under the car (the fuel filter side). Then you can tie the new pipe to the string and pull it back up from inside the car, saves you fiddling about guiding it between the tank and chassis  :smiley:
Golf IV 1.8T AUM
Golf V GT TDI PD170
Offline km
« Reply #4 on: 06 November 2012, 10:23 »
thanks for the info, how do the tank straps undo? don't really fancy having a look until i've got the replacement pipe.
Offline Gabriel2202
« Reply #5 on: 06 November 2012, 18:24 »
Pipe was about £17 inc VAT from VW and the straps just have an 10mm nut either end iirc. just make sure the tank is supported when you undo the straps (maybe with a plank of wood on a jack) and don't break the straps. Then lower the tank about an inch and should be alright.
Remember that the weight of the tank may shift depending on how much fuel is in it so just take your time and make sure everythings secure and level when undoing the tank straps
Golf IV 1.8T AUM
Golf V GT TDI PD170
