Author Topic: Building a false floor  (Read 2908 times)
Offline Khare
  • The bear that khares
« on: 05 November 2012, 14:17 »
Going to be making a false floor to avoid the carpet sinking down into the empty spare wheel well. Been looking around and I can't decide on what material and what thickness to use.
11mm OSB was one suggestion, but it seems heavy.
MDF is another choice, but how thick? 6mm, 9mm, 12mm? Needs to be thin enough to be lightweight (going to be building a trapdoor to the spare wheel well) but also strong enough to not break when I put stuff in the boot (mainly shopping bags and travel luggage, sometimes tools likes hydraulic jack and toolbox).
So, suggestions please?
Offline supergeeman
  • 97/P GTI8v
Re: Building a false floor
« Reply #1 on: 05 November 2012, 16:59 »
6/9mm mdf will bow/sag over time, with a constant load, without some supports screwed/glued on the underneath...how do i know? used it to bulk up my sagging sofa!
I'm not normally a praying man, but if you're up there, please save me, Superman!
Offline Khare
« Reply #2 on: 05 November 2012, 17:44 »
Funny cos my sofa has some 12mm MDF underneath and it's sagged too  :laugh:
Mind you 60+kg for extended periods is much more than maybe 20kg for an hour or two every full moon.
Offline Tazzy
« Reply #3 on: 05 November 2012, 20:17 »
9mm with a 9mm skeleton underneath should be strong enough and light enough, certainly less than if you had a sub box :)
If It Comes Off, Modify It!
Offline Khare
« Reply #4 on: 05 November 2012, 20:25 »
Just to clarify, there's no audio equipment going in the boot. My ICE goes as far as the headunit and the 4 door card speakers and tweeters.
Offline Deano2711
  • 1992 VR6
« Reply #5 on: 06 November 2012, 06:59 »
I used 12mm mdf with 4  runners/supports made of 2x2 softwood. Never had any probs with a boot full of shopping but never had a trolley jack in there because of my sub but it would have easily taken the weight.
Offline Khare
« Reply #6 on: 06 November 2012, 09:59 »
Sweet. Was hoping for mdf as it's easy to cut and sand. Got some mdf sheets at home from a few years ago, I'll make the supports out of them.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #7 on: 11 November 2012, 23:11 »
Where's the space saver gone then?
Offline Seanl
« Reply #8 on: 12 November 2012, 19:27 »
Hope you do it in a well ventilated space, with a decent dust mask! That sh!t is banned in most countries throughout Europe!
« Reply #9 on: 12 November 2012, 20:11 »
Not quite correct, ive also heard rumours that it was banned in the US but after some snooping it would appear not...entirely.
http://www.hse.gov.uk/woodworking/faq-mdf.htm
