Author Topic: Cruise Control, Mk6 GTI  (Read 4875 times)
Offline orcades
« on: 05 November 2012, 12:38 »
Hello All,
I've searched through the forum, and there's a good few threads about cruise control, however nothing really answers my query.
I've a Sept 2009 Mk6 GTI, and I'd like to fit Cruise Control, the following link seems to be the correct part (1K0054690B)
http://vag-shop.co.uk/store/cruise-control-kit-vw-golf-mk6/prod_13.html
I do have VCDS (Vag-Com), however I just wondered if it's much hassle to fit the Cruise Control stalk? If there's a guide somewhere - could somebody point me in the right direction, please.
Regards,
VW Golf GTI Performance Pack, Manual, 5Dr, Deep Black, Rear View Camera, Adaptive Chassis Control, Climate Windscreen, Park Assist, Winter Pack, Discover Nav Pro, Keyless Entry, Side Airbag System, High Beam Assist, Dynaudio. Ordered 26/08/2013, Collected 12/12/13
Offline Mr GTD
Re: Cruise Control, Mk6 GTI
« Reply #1 on: 05 November 2012, 13:13 »
That one says its for a MK4, doesn't it?
Your dealer shud do it for about £188 fit? Last time I checked they did any how...
Offline orcades
« Reply #2 on: 05 November 2012, 14:15 »
Hello Mr GTD,
The link says,
Part Number 1K0054690B. Application VW Golf MK6 2009-22/2009, and price £66.
The reason I'm planning on fitting it myself is because the nearest proper VW dealer is a long way away from me.
Regards,
Offline mwad gti
« Reply #3 on: 05 November 2012, 15:26 »
Maybe I am misunderstanding this.....
A VW dealer CAN (?) retrofit cruise control for approx £ 188 or so ?
Candy White 3 dr Manual 2012 GTi. Bought new.
DAB, Dynaudio, Kenwood Head Unit Upgrade, Private Plate,
Full Leather and Heated Seats
18" Shadow Monzas, luxury pack.
Colour coded side skirts and gloss black diffuser.
Offline Edi35
« Reply #4 on: 05 November 2012, 15:35 »
Yes they can, had it fitted to my MK5 ED30 at delivery as it was about £100 cheaper than a factory fit at the time.
Used it a lot but ultimately gave up using it in the UK as the roads were too busy as I was always having to adjust my speed to the conditions and found that using my foot was easier and gave better MPG than cruise. Only really used it when in France and on deserted motorways so was a waste of money for me.
The best use for the Cruise functionality is if you have APR software and use this as the switch to change to different maps, not sure if APR still use this though.
Current: GTI Edition 35 Candy White 5dr DSG 19" Glendale, RCD510+DAB, Dynaudio, Storage Pack, Parking Sensors
Gone: Edition 35, GTI Mk6, Edition 30, GTI Mk4, GTI Mk3, GTI Mk2 and my favourite the UR quattro
For those that dont know DSG is an electronically controlled dual-clutch multiple-shaft manual gearbox
Offline orcades
« Reply #5 on: 05 November 2012, 16:28 »
From what I've read so far, the gist of it is that it's a lot cheaper to fit Cruise Control to 2009/2010 Mk6 Golf's.
If a good dealer was closer to me I'd go for the dealer retrofit, however the nearest decent dealer to me involves a ferry and a longish drive.
I just wondered if anybody could confirm if the Cruise Control Part Number 1K0054690B is correct, and any info or tips on fitting would be appreciated.
Regards,
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #6 on: 05 November 2012, 18:58 »
Yours like mine will have the earlier mk5 arms. If you do a search on Google there was when I looked ages ago lots of how toos
There may even be one in the mk5 section on here. It's basically the same on the early mk6s (you don't need to fit the extra wire early mk5 s do.)
« Last Edit: 05 November 2012, 22:05 by Snoopy »
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline orcades
« Reply #7 on: 05 November 2012, 21:56 »
Thanks for the information Snoopy. I did come across a how-to for fitting Cruise Control to the Mk5 Golf, so I'll have a look at that again. I wasn't sure whether-or-not the Mk5 fitting instructions applied to the Mk6.
Regards.
