Author Topic: central locking  (Read 1502 times)
Offline golfgti818
central locking
« on: 14 July 2005, 23:33 »
Ok my central locking stopped working today. Any known problems to go straight for or have i really got to go through all those vacum pipes??
Offline Dannyd
  • LOOK AT THAT VALVER GO!
Re: central locking
« Reply #1 on: 15 July 2005, 05:20 »
check pump and fuse and mater switch in drivers door then vacum pipes
wacked up on scuby snacks!
Offline Rain
  • forum irregular
Re: central locking
« Reply #2 on: 15 July 2005, 08:14 »
if the pump is making a noise then WD4- is ya mate spray a mist over the tubes and joints see if youve sprung a leak if not then pumps likely had its day.
Judderi
Re: central locking
« Reply #3 on: 15 July 2005, 09:09 »
Check all your fuses first then start looking inside the drivers door for problems.
Offline Gambit
Re: central locking
« Reply #4 on: 15 July 2005, 13:11 »
you can operate the pump by hand this will tell you if its the pump or the accuator in the door
Offline hachi-roku
Re: central locking
« Reply #5 on: 15 July 2005, 19:18 »
Without sounding dippy.... mine has packed up as well recently, how can you activate it manually?  :huh:
Offline sesterfield
Re: central locking
« Reply #6 on: 16 July 2005, 02:12 »
sorry to hijack :P mine semi-works, albeit very very slowly.  Any ideas?
Offline monzablue16v
Re: central locking
« Reply #7 on: 16 July 2005, 14:22 »
Sounds like you have a sticky pump sesterfield its in the boot in a polystyrene box have  a look  at it and click the boot catch over and see if it moves freely when you lock the car.
