Author Topic: Fitting a TIP  (Read 933 times)
Offline MC_PEA
Fitting a TIP
« on: 02 November 2012, 13:17 »
I'm trying to fit a forge TIP but I can find away of getting it on the car. I've tried taking the turbo off and fitting it, but my problem is there is a hard coolant line that is in the way so I cant get the turbo back on with the TIP fitted. How did you lot get them on?
Offline wessexgti
Re: Fitting a TIP
« Reply #1 on: 02 November 2012, 15:10 »
God,this brings back memories of watching 2 machanics trying to fit my TIP  :laugh:
apparantly,you can slightly slacken that coolant line just enough to squeeze the TIP into place.apparantly!
im assuming your going at it from under the car?
good luck,im sure someone way more skillfull with the spanners than me  will advise you
Offline rio_gti
Re: Fitting a TIP
« Reply #2 on: 02 November 2012, 17:13 »
yeah do it with turbo on, slightly slacken water line, slip it down fron the top then gey under to get it onto turbo.......... is very tight!!!
Offline MC_PEA
Re: Fitting a TIP
« Reply #3 on: 02 November 2012, 17:36 »
I managed to do it by cutting the end of the pipe down
Still was a bugger tho
Offline rockmonkey69
Re: Fitting a TIP
« Reply #4 on: 02 November 2012, 21:37 »
You should be able to 'slot' it in place, try get the top to sit on the turbo then slide the bottom on. It is one of them diddly things sometimes it pops in first try and it's done in a couple of minutes start to finish other times you could be there for an hour if it doesn't play ball. But essentially there is enough space with the coolant line to the heater matrix in place.
Fortunately for me I don't have coolant lines to contend with.
Offline Dalo Harkin
Re: Fitting a TIP
« Reply #5 on: 06 November 2012, 13:13 »
I spent around 5 minutes trying to get the coolant line out of the way, then tried about 4 times from the top and it didnt play ball, and on the last attempt it just slid on, lots of cursing was done  :grin:
if it went on first time I would have been done in 10 minutes
