Author Topic: EGR delete  (Read 2568 times)
Offline shaft69
EGR delete
« on: 02 November 2012, 13:02 »
Deleting egr on 130 does it have to be mapped 1st with delete file or can be done on standard map?
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline sveed1.8T
Re: EGR delete
« Reply #1 on: 02 November 2012, 13:11 »
Doesn't it throw up an error code until it is mapped out? :undecided: Don't think there's an issue driving it though..
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: EGR delete
« Reply #2 on: 02 November 2012, 23:12 »
Can be done on a standard map. At least on my 150 and my bros 130s we installed the EGR delete and no error codes.
Have only heard about the error codes with really early model PDs.
Offline old_n07
Re: EGR delete
« Reply #3 on: 03 November 2012, 10:32 »
It depends on the car, some of the later 130's and 150's throw the engine management light without the egr and some don't it is entirely dependent on the ECU suoftware, generally if the car is mid 2003 or older you will be OK
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline sveed1.8T
Re: EGR delete
« Reply #4 on: 03 November 2012, 13:51 »
So generally if you own a mk4 then? :whistle:
