Author Topic: Help with lowering issue  (Read 907 times)
Offline UKChrisT
« on: 02 November 2012, 10:40 »
Hi,
I recently bought a MK4 2.0 8v, and I'm now looking to buy a set of AP coil overs (seen here; http://www.dpmperformance.co.uk/ap-coilover-suspension-kitbr-golf-4-14-16-18-18t-19sdi-19tdi-20-23-v5-fwd-1097-p-5086.html)
I am currently running 225/45/17, how low would you suggest I go?
I was thinking 45mm all round? I don't want to experience any issues such as oil sump rubbing or drive shaft, apparently this occurs a lot when lowering more than 45mm?
Any help would be appreciated as I haven't owned a mk4 previously or lowered a car before.
I want it to look low (with as little arch gap as possible) but I don't want to experience any problems a long the way.
Offline mcgee9t2
Re: Help with lowering issue
« Reply #1 on: 02 November 2012, 12:39 »
arb problems are different on everyones car tbh. general rule is around 40 mm. however mine is lowered 100mm and still only rubs on very full lock (i.e the last 2cm of turning the steering wheel) (will be raising it 20mm soon (as at 80-90mm ive never had rubbing) to stop this so i dont nak my steering rack untill i get the vrs arb from a mate)
sump problems, depends were you live, i have a bit of a problem in darlington cause some of the speed bumps around there are large, however some of the speedbumps were i work are tiny so have no problem, you will soon learn what you can and cant go over and how fast to take speed bumps
