Author Topic: No power  (Read 1222 times)
Offline stace110
No power
« on: 01 November 2012, 21:22 »
Hi all just a quick one,
My car feels very flat ...no power... it feels like n/a 1.8 but you can hear the turbo its very whistley....if thats spelt right lol?
Its a 1999 AGU lump with cold side dumpvalve and not mapped and no boost gauge  ....I know they arnt the quickest cars but it just feels FLAT .
I know i have a leak on the de-cat downpipe joint but still it feels like theres no torque.
Any help would be great .
1999 AGU, sitting on Dotz 18's,forge 008p, r32 side skirts. satin silver....more to come
Offline james2
  • No scammers please.
Re: No power
« Reply #1 on: 01 November 2012, 21:48 »
I would scan it to check for any faults first.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline barrym381
Re: No power
« Reply #2 on: 01 November 2012, 21:55 »
when you say dumpvalve what kind  :smiley:
Offline stace110
Re: No power
« Reply #3 on: 01 November 2012, 21:56 »
Hi james,
I scanned it the other day on a snap-on reader for some reason i have no power going to the obd port. all that was there was temp sensor ...
Offline stace110
Re: No power
« Reply #4 on: 01 November 2012, 21:57 »
Baileys motorsport dv
Offline barrym381
Re: No power
« Reply #5 on: 01 November 2012, 21:58 »
swap this for a forge 007 or 008 check for boost leaks from split pipes aswell  :smiley: would sort the exhaust too
« Last Edit: 01 November 2012, 22:01 by barrym381 »
Offline Dalo Harkin
Re: No power
« Reply #6 on: 02 November 2012, 10:33 »
As the others have said check the basics, then you need to look for split pipes with oil on ( oil indicates boost leaks! )
are you running a standard filter setup?
You need to get it properly scanned, with VAGCOM if you can and see what it throws up
Offline Ant1981
  • Feed me, prod me
Re: No power
« Reply #7 on: 02 November 2012, 10:33 »
Don't worry about your spelling, no one else does.
It sounds like a boost leak. Quite a common one is the diverter valve. May be worth changing that, as well as checking the hoses over.
'09 Kawasaki Ninja ZX-6R
Offline jamie1989
Re: No power
« Reply #8 on: 02 November 2012, 10:48 »
A standard AGU is flat and feels rubbish.
Yes you may have old pipes perished but even when youv replaced the perished pipes if you have any its still going to feel rubbish and slow.
My advice is do as above buy a forge 007p, check for split pipes ( Good idea to start at air filter down to the turbo, up through the intercooler pipes and back to the inlet mani. Any splits found here will affect your cars peformance)
Also check your PCV breather system, this is all under vaccum also. So from the rocker cover youl see a 90" pipe go from there and follow it under the inlet and replace/fix any pipes or replace with catch can mod.
Then when your happy everything is in good working order either throw the little turbo away and replace with a good second hand k03s (later model turbo bolt on no mods required) then a cheeky remap will see above 200bhp and you wont be saying its flat anymore  :grin:
Or keep the turbo on and youl see around 185-195bhp after a remap.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline stace110
Re: No power
« Reply #9 on: 05 November 2012, 15:59 »
Cheers for the replys guys, i'll have a good detailed look tomorrow .
