Author Topic: where would you start  (Read 1320 times)
Offline (shakey)
  • IS STILL SICK ABOUT CRASHING ME 1.8T AFTER 2 YEARS
« on: 01 November 2012, 19:31 »
ran vagcom and came up with this dont know where to start.
17545/P1137/004407 - Fuel Trim: Bank 1 (Add): System too Rich
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Mass Air Flow (MAF) Sensor faulty
Fuel Pressure Regulator faulty
Fuel Injector(s) faulty
Oxygen Sensor Control faulty Oxygen Sensor(s) faulty
Evaporative Emission (EVAP) System faulty
Possible Solutions
Check Mass Air Flow (MAF) Sensor
Check Fuel Pressure Regulator
Check Fuel Injector(s)
Check Oxygen Sensor Control Check Oxygen Sensor(s)
Check Evaporative Emission (EVAP) System
Special Notes
Fuel Trim Information
Offline rio_gti
Re: where would you start
« Reply #1 on: 01 November 2012, 20:16 »
Clear the code and pretend you never saw it   :lipsrsealed:
Live log think its group 031 032 033 around there bd see what the lambda/ fuel trims are saying
Offline (shakey)
« Reply #2 on: 01 November 2012, 23:24 »
Ok will try that cheers
Offline Nino
« Reply #3 on: 01 November 2012, 23:37 »
I had this and I found out that it was the throttlebody that needed cleaning.
Current - MK6 GTi Edition 35
