Author Topic: Trouble starting  (Read 2882 times)
Offline hillergoose
  • Novice with time on his hands
Trouble starting
« on: 31 October 2012, 21:39 »
Hey. some mornings after a spell sat in the garage for a few days it has trouble starting and very occasionally back fires.......fuel pump? new leads & plugs needed?  Thanks
Offline raferackstraw
Re: Trouble starting
« Reply #1 on: 01 November 2012, 09:11 »
1st check for spark, then check for fuel, it would help if you gave a bit more info as to which engine, does it crank slowly?
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline hillergoose
« Reply #2 on: 02 November 2012, 21:04 »
cheers. '89, 1.8 gti.....it sometimes does crank slow yes. Tempermental at times. could be stood for weeks and start 1st time, stood for a day and its a right chew on
« Reply #3 on: 02 November 2012, 21:57 »
cranking slowly is bad with fuel injection check your battery, get a multimeter across the terminals you should above 14v with engine running, check the conections at starter motor and xclean up all earths in engine bay, give it a good service plugs, dizzy cap rotor arm, check cold start injector is working this is essential for starting when cold
Offline hillergoose
« Reply #4 on: 07 November 2012, 19:47 »
superb mate. thanks
