Golf mk2
Calipers
Topic: Calipers (Read 1313 times)
Baz16v1
Calipers
31 October 2012, 20:54 »
Hi do golf vr6 calipers fit straight onto golf gti 16v or will I have to mod to fit
Mr Blue
Forum addict
Re: Calipers
31 October 2012, 22:15 »
Find the 280mm disk setup and use 4x100 g60 disks. not sure on the 288 unless its just the the caliper carrier thats different. Girling 54's calipers are the ones you need.
Last Edit: 31 October 2012, 22:32 by Mr Blue
Gambit
Forum addict
Re: Calipers
01 November 2012, 00:07 »
You need 280mm carriers n calipers found on early mk3 vr6 & 16v. You cannot fit later 288mm calipers and carriers to a mk2 4stud hub
and your mk2 16v needs to be running 256mm setup, or else youll need to changes hubs also
plenty of info on search
Last Edit: 01 November 2012, 00:09 by Gambit
Golf mk2
Calipers
