Author Topic: golf clocks  (Read 1358 times)
Offline liss-liss
golf clocks
« on: 31 October 2012, 20:26 »
I need some new clocks as mine are 20mph out and the mileage screen has bled. Iv found some replacement clocks on ebay with the same code as on the back. I know i have to have them coded and all that jazz. BUT am i able to fit bora sports clocks instead even thou they have a different code on the back? any help appreciated!
2.0 mk4 GTi
Just because I'm a girl doesn't mean I not a racer.
Delta-Force
Re: golf clocks
« Reply #1 on: 01 November 2012, 02:06 »
yes bora sports are a popular mod pal they wil fit if the part number ends in a 5 there immo 2 and if its a 6 there immo 3 so you can have miles till empty and lit needles enabled on them just make sure they are for a petrol if yours is a petrol you can tell by the rev counter the tdi ones will only go upto 5k hope this helps  :cool:
Offline SI74
Re: golf clocks
« Reply #2 on: 01 November 2012, 07:48 »
You need to know what your own clocks are as well because. You can put an immo 3 cluster into an immo 2 car (upgrade) but not an immo 2 cluster into an immo 3 car (downgrade)
Offline rio_gti
Re: golf clocks
« Reply #3 on: 01 November 2012, 07:51 »
i’m calling from mobile service providings, wondering if you wanted to downgrade your upgrade to a grade that is a higher grade than your current grading.
Offline xtetx
Re: golf clocks
« Reply #4 on: 01 November 2012, 08:44 »
ive got bora v6 clocks in mine, they are immo 3. They average of about £100 if people know what they are selling, lots of people seem to upgrade them to these or the anni clocks.
Offline liss-liss
Re: golf clocks
« Reply #5 on: 01 November 2012, 08:51 »
Thanks for the help guys. found some on fleebay for £60 so sounds like a deal. just need to price up coding now and ill be able to do the speed limit again :D
2.0 mk4 GTi
Offline xtetx
Re: golf clocks
« Reply #6 on: 01 November 2012, 08:58 »
That is cheap!
Offline liss-liss
Re: golf clocks
« Reply #7 on: 01 November 2012, 08:58 »
yup! perfect working order too.
2.0 mk4 GTi
