Author Topic: footrest cover  (Read 2550 times)
Offline dereks
footrest cover
« on: 31 October 2012, 18:51 »
Just bought myself a 59 plate candy white gti so as a treat and looking through this section I got myself the alloy footrest that many recommend :smiley:
Question is people have mentioned sticking it on with tape but mine came with nuts and bolts so do you remove the footrest first to attach?
Derek
« Last Edit: 31 October 2012, 19:01 by Mr GTD »
Offline Mr GTD
Re: footrest cover
« Reply #1 on: 31 October 2012, 18:59 »
Hi
You shouldn't need to remove anything to fit the footrest just some strong 3M tape then a firm press shud do the trick...well it has for me any how.
And if you got holes then its the wrong one...I think it's the MK5 that required the holes...
« Last Edit: 31 October 2012, 19:02 by Mr GTD »
Offline Arena8
  • "A mans a man fur aw that"
Re: footrest cover
« Reply #2 on: 31 October 2012, 19:13 »
I just got my 35 footrest the other week from Gulfstream and stuck mines on with "No Nails" exterior double sided tape. No problem :smiley:
Edition 35 * Deep Black * RNS 510 Sat Nav * ACC * Park Assist with camera * Luxury Pack - Folding mirrors * Sunroof * Coloured DIS * ED35 Dice* Interior LED bling* ED35 footrest* 35 rear badge* Mudflaps- fronts customised fit
Offline dereks
Re: footrest cover
« Reply #3 on: 31 October 2012, 19:18 »
Thanks i got it from the bay so I've sent them an email to clarify it on the listing it's says mk5 and 6
Probably send it back and get the off here
Offline Mr GTD
Re: footrest cover
« Reply #4 on: 31 October 2012, 19:23 »
Gulfstream11(forum name) does them on here and over on the MK5 forum which is where I think he spends more time..
When I ordered mine from him he asked if I wanted the one with the holes or the one that sticks like glue(no holes)
If it was a reputable Ebayer I'm sure you won't have any probs in sending it back...
Offline dereks
Re: footrest cover
« Reply #5 on: 31 October 2012, 19:31 »
Thanks for that sure it will be fine seems a big seller called creation motorsport
Offline Raffe
Re: footrest cover
« Reply #6 on: 31 October 2012, 19:56 »
I have the rest with holes and find it looks fine, would never remove it so he holes aren't ever going to be a problem  :smiley:
Offline Jimble
Re: footrest cover
« Reply #7 on: 31 October 2012, 20:46 »
I bought some plate carriers from them a little while back from their shop in Brum, i decided i couldn't be bothered taking the original mount off the front so took them back and they were fine with it. :afro:
Offline Snoopy
  • Moderator
  • Geoff.
Re: footrest cover
« Reply #8 on: 31 October 2012, 21:33 »
Mines a mk6 one from gulfstream with the bolts fitment.
If you look in the foot well its easy to see iirc its two plastic nuts to remove the oem one to fit the new plate on it. + the oem replacement is less than a fiver as I bought one just incase.
« Last Edit: 31 October 2012, 21:35 by Snoopy »
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline dereks
Re: footrest cover
« Reply #9 on: 31 October 2012, 22:02 »
Will have a closer look tomorrow it's been peeing down all day here.
