Author Topic: which top mounts?  (Read 3779 times)
Offline sharki786
  • GOT BOOST??
which top mounts?
« on: 31 October 2012, 11:37 »
my car is lowered on jom blueline coilovers, i fitted new top mounts all round (febi) after 3 years they are fooked. So i was thinking poly bush top mounts. After looking on net & ringing a few companies, i cant get hold of any. Who has poly bushes in their ride?
Also if you have lowered your car & had them fitted for more then 2 years & your mounts dont creak, which mounts have you fitted?
P.s roads down here are poop!!!
Let me know pleaseeeee
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Khare
  • The bear that khares
Re: which top mounts?
« Reply #1 on: 31 October 2012, 11:51 »
Use normal febi top mounts. I've heard many many nasty things about poly top mounts, including MOT failures.
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 31 October 2012, 12:36 »
i have febi on them atm, they have failed its been 6 months now & now its eating my tyre :cry:
*****MK4 GTI T*****
Offline Khare
« Reply #3 on: 31 October 2012, 12:41 »
Thought you said 3 years?
Anyhow, when running coilovers you're always going to go through top mounts more often. Stick to febi  :smiley:
Offline Len
« Reply #4 on: 31 October 2012, 12:44 »
Eating tyres probably means you havent had the alignment done on your car!
www.sas.org.uk
www.the-ace.org.uk
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 31 October 2012, 12:55 »
sorry to confuse you guys. i had them fitted for 3 years now (coilovers & all 4 top mounts)
they have been creaking for 6 months now.
after my uncle fitted the coilovers, i took the car for its alignment, it was superb but recently my passanger side tyre is being eaten away & im getting creaking from the passanger front side.
ps what about the vr6 mounts? will they be tougher or are they the same as the 8v? as i remember before people were saying to get the vr mounts
*****MK4 GTI T*****
Offline Khare
« Reply #6 on: 31 October 2012, 12:57 »
Just replace the top mounts with new febi ones and get alignment done  :smiley:
Oh and check condition of wishbone bushes, they could be causing the excessive tyre wear.
Offline sharki786
  • GOT BOOST??
« Reply #7 on: 31 October 2012, 13:37 »
poly bushed the wishbones with flo-flex (same as yours)  :wink: they was done under a year ago. i had a quick look at them last week and they seemed ok
il just get the febi 1's
*****MK4 GTI T*****
Offline Khare
« Reply #8 on: 31 October 2012, 13:55 »
Bushes will be fine then  :smiley:
Stick to standard rubber top mounts as I said mate, heard lots of horror stories of the poly mounts not sitting snug and needing trimming to fit properly, squeaking and even failing MOT's for whatever reason + they'll reduce the comfort in the cabin a lot.
Oh and definitely buy Febi, from tie-rod69. Don't bother with cheap mounts, I had to replace my "great value" top mounts after a few weeks.
Offline trog_nfs
« Reply #9 on: 31 October 2012, 14:04 »
I bought my top mounts from the dealer. They had lasted 15 years no problem
