Author Topic: Airbag light problem, Will a resistor do?  (Read 3153 times)
Offline Xtrhardcore
  • Mk3 Gti 2.0 8v MoreDoor
« on: 30 October 2012, 20:16 »
Guys,
I've just changed my steering wheel to an aftermarket one that does not cater for airbags.
The air bag light is on as you would expect, but i can't clear it? I've tried to erase the code it says its erased but its still on!!
I've plugged the switch back in so i can wire the horn in, but obviously had to snip the wires that connected to the airbag...
Question is, if i run a resistor between the wires will this allow me to disable the light?
any advice?
Cheers!
« Last Edit: 10 November 2012, 10:41 by Xtrhardcore »
Mk4 Gti - Gone but not forgotten!
Offline rio_gti
Re: Airbag light problems! Advice needed:
« Reply #1 on: 30 October 2012, 20:18 »
Prob a resistor will be needed but I'm not clued up on bags  :rolleyes:
Offline Xtrhardcore
« Reply #2 on: 30 October 2012, 20:26 »
was thinking the same thing earlier :P Do you know how i would fit a resistor and the best one to get? :)
Offline Xtrhardcore
« Reply #3 on: 31 October 2012, 10:57 »
Anyone :)
Offline mcgee9t2
« Reply #4 on: 31 October 2012, 12:48 »
sure you need vagcom to disable the airbag light?
might be possible with vag tacho too but not sure?
take it to a garage if you dont have vagcom, they should only charge a tenner to do it if you take it to a smaller garage. or have a look see if anyone off here has it and can do it for a few beer tokens
Delta-Force
« Reply #5 on: 01 November 2012, 02:10 »
just code out the airbag light with vag com pal go into can gateway and change the softcode from 0006 to 0002 this will code out the airbags you may as well do this as the airbags are disabled anyway with no steering wheel airbag :cool:
Offline clancy
« Reply #6 on: 01 November 2012, 10:20 »
As above or use a resister that's like 30p from maplins, lots of guides online for that bud
MK3 GTI 16v
Offline Xtrhardcore
« Reply #7 on: 01 November 2012, 18:30 »
Lovely cheers guys :)
Offline Xtrhardcore
« Reply #8 on: 03 November 2012, 11:53 »
Will a resistor trick the system into thinking the airbag is still attached? Will this resolve the problem so that the other airbags will deploy in an accident?
What resistor should i grab?
:P
Offline Xtrhardcore
Re: Airbag light problem, Will a resistor do?
« Reply #9 on: 10 November 2012, 11:12 »
TTT still not solved!
