Golf mk4
Wazzzer
I'm baffled some help please
Topic: I'm baffled some help please (Read 2012 times)
1stevester1
GTI forum regular
30 October 2012, 19:04 »
this problem has stumped I brought car not so long ago and it seemed to have boost problem I could feel it kick then stop then kick in again so got a code reader and yup it came up with 17705 boost leak great so I reset the code as it was they only one that came up took the car for a quick td and it was jerking and I couldn't accelerate so came back disconnected the maf it drives like it did before so I baffled maf was fine before but now not cannot see that resetting a code has caused the maf to be knackered it's and auq if anyone could come to the rescue most appreciated
1stevester1
GTI forum regular
Re: I'm baffled some help please
30 October 2012, 20:35 »
Any one
GTi_James
30 October 2012, 20:48 »
check breathers, any cracked pipes...can you fit a catchcan in auq? also clean out the throttle body, check your filters and when was the last service?
1stevester1
GTI forum regular
30 October 2012, 20:51 »
Pretty sure is a dead maf as apparently the ecu would of made it sort of work with it dead then I ve reset the code and it wants to read it as in it being working lol took me a while
GTi_James
30 October 2012, 20:53 »
lol definitly a head scratcher, and youve replaced your maf? with oem? and it was running fine when you bought it?
1stevester1
GTI forum regular
30 October 2012, 20:59 »
Yup running fine but you could feel the turbo kick in then slightly hold ack and then kick back fitting a boost gauge the weekend to try sort that one out. But the maf yeah definetly got me thinking so going to replace it with an genuine unit tomorrow then check for codes again
rio_gti
"i'm not spending any money on it" Got a Hybrid!
Reply #6 on:
30 October 2012, 21:05 »
Mine had that sort of problem, think it was the n75 valve at fault, spikes early then boosts when needed, so basically it overboosts befor it's ment to
haven't explained well but hopefully u get the gist of it!!!
2000 GTI 1.8t ARZ, S2000 filter, DSG intake, Forge 007 dv, Catch can, R-tech custom remap, 3" Supersize Silicone TIP, Powerflex dog bone, 'The Beast' FMIC, Ultimate delete, LCR fuel pump, 3" Turbo back, K03 hybrid, Ported Manifold, S3 injectors, 80mm maf = 280bhp 270lbft
1stevester1
GTI forum regular
Reply #7 on:
31 October 2012, 18:27 »
Did it come up when you scanned it ?
rio_gti
Reply #8 on:
31 October 2012, 18:33 »
Never scanned it, r tech told me it was at fault when I had it mapped, so when I got back I put a new one on and it's been fine ever since!!
1stevester1
GTI forum regular
Reply #9 on:
31 October 2012, 19:18 »
Did boost up to say 22psi then drop to 16 then upto 22 again then back down as that's what's going on with mine now
Golf mk4
Wazzzer
