Author Topic: will be getting it serviced agen ? should i stick with standard stuff ?  (Read 2098 times)
Offline Itteh
  • Built Not Bought
will b gettin the 8v serviced agen, should i stick with standard NGK spark plugs, or get platinum ? do they even fit in the 8v ? will it make any difference ?
Offline tweed
Standard stuff mate.
Turbos benefit from plugs but a 2.0 8v won't
Some people say they do, but replacing old spark plugs with new ones is a improvement.
Offline Itteh
  • Built Not Bought
hmm i seee, i need rear carriers, mine are rusted cant change the rear brake discs, where can i get some from ?
Offline tweed
Classified or ebay
Offline Itteh
  • Built Not Bought
wont they be the same if there off an old mk3 ?
Offline tweed
No
Mine are mint
Offline Itteh
  • Built Not Bought
il have to find some then... arghhh
Offline Bellend
Why would you need new carriers?
So what if they are rusted? Do you mean bolts?
Carriers rusted = bench grinder on the wire brush side.
Where all my moneys went.
Offline Itteh
  • Built Not Bought
the bolts, they need grinding off... so il need the carrier and the bolts....
Offline Bellend
Why carrier?
Just need new bolts surely. Irwin extractors will sort it. Or do you mean calliper bolts?
