Author Topic: Little update on my 16v anni, 6m on  (Read 6769 times)
Offline berry9112
Re: Little update on my 16v anni, 6m on
« Reply #20 on: 09 April 2013, 10:55 »
Good work bud, looks alot cleaner. Although that exhaust is annoying me! needs to be higher into the bumper personally. What do the magnex systems sound like?
Offline Leroy
  • Golf GTI Anniversary 16v
« Reply #21 on: 09 April 2013, 11:18 »
Yes i thought that, i had to have a new bracket welded on so it would fit, i was told it came off a 16v but obviously not, (i thought the 8v,16v and vr6 were the same). I think it sticks out a bit far and hangs a bit low, but im skint now so will have to live with it.
It is quieter than the standard one i took off (its only the back box by the way) but that used to rattle like mad, you can tell its on but its not loud at all, gives a nice note when your giving it a bit of throttle though, im happy with it and my neighbours will be as well at 6 in the morning!!! not too in your face.
Offline SimonG
« Reply #22 on: 09 April 2013, 15:18 »
That's a nice looking Anniversary. What lining tape did you use for the bumpers and trim?
  Mk3 Anniversary GTI 16V, Mk2 GTI
Offline Leroy
« Reply #23 on: 09 April 2013, 15:30 »
Halfords mate, think its 3 or 5mm, found it on a search on here, does the job.
Offline Shady Pioneer
  • graphic designer.
« Reply #24 on: 09 April 2013, 15:49 »
Looks good but my god sort out that exhaust.  :evil: The 8v exhaust is a different size to the 16v and VR6 (which are the same).
Think I may get some of that tape, bring back the red on my bumpers as the pinstripe has faded a fair bit.
Keep up the good work.
Offline spudboy6
  • Just like a golf ......
« Reply #25 on: 09 April 2013, 23:36 »
i have a magnex cat back with centre box delete on mine , not that loud unless you give it beans and 70+ its loud but can be quiet when you want it to be
to sum up sounds good , want to get a single tip box for mine now as they annoy me how they never sit straight , but made mine fit with the help of my welder and some cuttong here and there , and worried if i get a new box i will end up with some fart cannon !
Offline berry9112
« Reply #26 on: 10 April 2013, 14:39 »
Cheers for the exhaust feed back guys. I want a new system on mine but dont want anything loud, something a bit raspy on over run ect. I too prefer single exits, purely because all the twin exit systems are too big and look daft.
Offline GOLF-MK3-GTI
« Reply #27 on: 10 April 2013, 14:44 »
Twin exits always look good on a MK3  :wink:
Offline Leroy
« Reply #28 on: 10 April 2013, 21:57 »
Agreed, had an oval single exit on my 8v stupid loud, looked cool but fancied a change, plus my anni had twin exit exhaust from the factory so its like an uprated version of factory spec. Its a bonus its not too loud until you give it some, you know its there but everyone doesn't think your a chavvy little pr**k!!!
Agreed though, need to have it not hanging so low so it looks less obvious.
Found some spacers in the garage as well so going to space the back out a bit as well so not so tucked, as long as it doesn't cause issues with the arches.
Offline Foreveryoungaus16v
« Reply #29 on: 10 April 2013, 23:00 »
Twin all the way :cool:
163 BHP (TSR POWER RUN)
