Author Topic: Water in the boot ?  (Read 1233 times)
Offline spudboy6
  • Just like a golf ......
Water in the boot ?
« on: 29 October 2012, 21:04 »
My boot carpet was wet today , lifted the carpet up and it seems to be coming out from under the plastic that runs the length of the boot by where the shut line is if you get me ???
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Water in the boot ?
« Reply #1 on: 29 October 2012, 21:28 »
Check out the foams seals around the rear lights clusters as these perish over time allowing water in.
Offline spudboy6
« Reply #2 on: 29 October 2012, 22:18 »
Will give that a look in the morning.  If they are leaking what do you do to re-seal or replace them with ?
Offline spikenipple
« Reply #3 on: 29 October 2012, 22:46 »
Buy new seals from VW, and if there is any rust or bubbling on the bodywork where the lights go then deal with that first otherwise the new seal probably won't seal very well.
« Reply #4 on: 29 October 2012, 23:35 »
As and when you fit the new seals use some silicone sealer as well.
