Author Topic: Anyone know if this is the right rocker cover gasket?  (Read 1630 times)
karls3abo
For a 1.8t Agu
Item number on eBay is
221033330676
Can't copy a direct link sorry
Also when replacing this is there any reccomendations on anything else that I should change when doing this?
Thanks Karl.
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
Re: Anyone know if this is the right rocker cover gasket?
« Reply #1 on: 29 October 2012, 19:28 »
Hi Karl, looks the right one, here is details of genuine one for your interest...
058198025A - gasket set for cylinder head cover - apx £23 inc VAT
and the ebay one is slightly cheaper from here: http://www.ebay.co.uk/itm/AUDI-A3-A4-A6-TT-VALVE-ROCKER-HEAD-BOX-COVER-GASKET-SEAL-058198025A-1-8-PETROL-/190737836112
Hope that helps  :wink:
Offline Mr_Orange
« Reply #2 on: 29 October 2012, 19:31 »
Looks correct, however I'd go for genuine for only a couple of quid more.
Deffo replace the tensioner gasket/seal at the same time and apply a drop of gasket seal on both as per :-
http://www.audizine.com/forum/showthread.php/275895-How-to-1.8T-Cam-Chain-Tensioner-Gasket-replacement
Its a good excuse to clean up and paint your rocker cover too  :grin:
Build thread clicky
karls3abo
« Reply #3 on: 29 October 2012, 20:06 »
Brilliant thanks guys, gone for the cheaper eBay one hope I don't regret that haha!
For the other tensioner gasket, has anyone got a link for one? Also would this come with the tool?
Offline Golf_GT_TDI
« Reply #4 on: 29 October 2012, 20:50 »
058198217 - gasket set for chain tensioner/camshaft adjuster - £7.15 inc VAT
Tool is not included, cheapest I found on ebay...
http://www.ebay.co.uk/itm/Camshaft-Retaining-Adjuster-Tool-FOR-VAG-VW-AUDI-ENGINES-OEM-3366-/160813469978
karls3abo
« Reply #5 on: 29 October 2012, 20:57 »
Brilliant, thanks just ordered both :) looking forward to the weekend already! I have a feeling that the cover gasket may be leaking as I have had a bit of oil in the bottom of one of my plugs, hoping this is causing the misfire under boost, got a bit of a tapping noise when the revs drop suddenly when revving, and also at a certain amount of revs. If this isn't it I'm not sure what it is! Replaced the maf ignition amp all the plugs next is the coil packs.
Thanks for you help muchly appreciated :)
karls3abo
« Reply #6 on: 29 October 2012, 21:02 »
Just to make sure is the right tensioner gasket?
eBay item number 380473536711
Offline Golf_GT_TDI
« Reply #7 on: 29 October 2012, 21:06 »
Yep that looks right to me mate  :wink:
karls3abo
« Reply #8 on: 29 October 2012, 21:08 »
Brilliant thanks guys. :)
