Author Topic: cutting out  (Read 1104 times)
Offline Minton1986
cutting out
« on: 29 October 2012, 15:43 »
i changed my battery on the weekend and since ive done that the car will start but cut out straight away! can anyone point me in the right direction in what i need to be lookin for for?
« Last Edit: 29 October 2012, 19:29 by Minton1986 »
Offline Agreeable Slick
  • Unit
Re: cung out
« Reply #1 on: 29 October 2012, 16:47 »
More than likely reset the immobiliser.
Make and model?
Offline Minton1986
Re: cung out
« Reply #2 on: 29 October 2012, 18:51 »
its a mk4 gti t. any idea how i can get it sorted please?
  • Unit
Re: cutting out
« Reply #3 on: 30 October 2012, 09:30 »
Unfortunately they are normally coded to the key, which means either you need to find someone/autoelectrician with VAGCOM, or tow the car for a painful trip to the dealers.
The first option obviously being the cheaper one, but ask for a full diagnostic scan first to highlight any more simple fixes.
FYI - whenever changing a car's battery you should try to keep a small amount of voltage in the system ~6V to keep the ECU alive and stop it resetting. Common mistake, but causes a right pain when it goes wrong.
