Author Topic: Abf gearbox conversion  (Read 1287 times)
Offline Jimmyrallye
  • 20vt goodness
« on: 28 October 2012, 22:09 »
Evening chaps just recently done a abf conversion in my mk2 got a couple of questions ..
1. Ive read some were but cant find it have tried searching that you can use a mk2 1.3 speedo cable drive to give me back my speed counter as abf is electronic .
2. Sinse doing the conversion everything went well and plugged the reverse light sensor back on but its not throwing my reverse light on ?? Could it be a dodgy reverse light on the abf gearbox ?
Thanks all :)
« Last Edit: 28 October 2012, 22:19 by Jimmyrallye »
Offline Dogbot
Re: Abf gearbox conversion
« Reply #1 on: 29 October 2012, 08:17 »
I believe that is the correct cable to use, and I suspect the reverse switch in the gearbox is dead, as my abf was plugged in an the lights worked, there was no other wiring to play with for these so yeah I'd start with the switch in the box
Offline Jimmyrallye
  • 20vt goodness
« Reply #2 on: 29 October 2012, 08:44 »
Good man dogbot ;)
Offline Diamond Hell
  • Opinions я Us
« Reply #3 on: 29 October 2012, 15:47 »
There's also an early Passat 3B cable you could use for the speedo.  May be the same, of course.
