Author Topic: Still lagging in 1st gear. Mechanic stumped. Likely cause?  (Read 5127 times)
Offline Steve_PD
Re: Still lagging in 1st gear. Mechanic stumped. Likely cause?
« Reply #10 on: 31 December 2012, 23:54 »
Block 11 for boost
Offline NotMyName
« Reply #11 on: 01 January 2013, 12:09 »
Thanks for the responses guys.
What is the solution then? To replace the actuator? If so, how easy is this to do? Is it a nightmare to get at or quite simple?
I had a gander looking for it: http://www.eurocarparts.com/car-parts couldn't find it on there So tried http://www.ebay.co.uk/sch/i.html?_trksid=p5197.m570.l1313&_nkw=MK4+Golf+TDI+actuator&_sacat=0&_from=R40 Cheapest item being £10 all the way up to £80 - so quite a range. What would be the correct item for the solution here? Or with something like this would you only buy from VW (& brace yourself for the bending over?)?
Offline Rhyso
« Reply #12 on: 01 January 2013, 12:27 »
Was the turbo a new one or an a 2nd hand turbo? As for approx £500 you could have had a brand spanker.....
You can adjust them and log the duty cycle. You are looking for anything in the 50-75% range when on full chat. Anything over will be working the turbo really hard or the turbo itself might be on the way out
« Last Edit: 01 January 2013, 12:30 by Rhyso »
Offline NotMyName
« Reply #13 on: 01 January 2013, 12:41 »
I tried looking for the eBay ad to link you but it's too old now. It was advertised as a brand new one. Correct part number for his too apparently.
My VAGCOM seemed pretty limited to what it could do beyond autoscan. Wondering if it's the USB lead side of it. He's not looking to spend a lot of money on it though, just enough to get it running right.
So are you saying that it'll likely not need replacing & just programming? IF it was to need replacing, is it hidden away & would require the engine ripping out or is it quite easy to get to?
EDIT: Sorry, just seen you said the problem is that it's not set up properly, not that it's faulty. My apologies - full of cold so am quite zombie like at the moment.
Offline Rhyso
« Reply #14 on: 01 January 2013, 18:19 »
You need to log the boost and duty cycle to determine if its faulty or just needs setting up
If it was a new turbo chances are it needs adjustment.  Mine was a new turbo and they are apparently setup from the factory  :rolleyes:
Offline old_n07
« Reply #15 on: 01 January 2013, 18:56 »
Here is some light reading for you link
Log block 11 to see what is happening boost wise :afro:
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
