Author Topic: Clutch problems  (Read 3495 times)
Offline luke
  • When in doubt, whip it out!
Clutch problems
« on: 26 October 2012, 15:18 »
Started happening recently, sometimes when driving and putting the clutch in to change gear it will click and be a bit stiff, then the clutch will bite lower and sometimes the pedal will not come back up, anyone had this problem, unsure what it could be
1985 mk2 gti type 19 8v
2018 t roc sel 1.6tdi
Offline Thom89
  • Looking for an "Icebreaker"
Re: Clutch problems
« Reply #1 on: 26 October 2012, 19:00 »
It sounds like the cable Luke, but could be wrong! I'd get a new cable fitted for how much they cost... but I wouldn't be surprised if the clutch is starting to drop to bits, with your description it could be either!
Thom
Offline jakethesnake180
Re: Clutch problems
« Reply #2 on: 26 October 2012, 20:20 »
Same as Thom says; sounds like the cable is seizing or starting to go.
Try soaking WD40 round the linkages both ends and pumping the pedal to see if you can free it up.
That might tell you either way.
Re: Clutch problems
« Reply #3 on: 26 October 2012, 21:13 »
Fit a new cable as the 1st step and see if it makes a difference.
Offline luke
Re: Clutch problems
« Reply #4 on: 27 October 2012, 10:12 »
Will get onto it next weekend as I'm skint
Offline luke
Re: Clutch problems
« Reply #5 on: 28 October 2012, 15:47 »
Fingers crossed it's sorted, the rubber bit at the end of the cable was out of line, moved it back in place and it seems fine, will give it a drive later to make sure, next job is insurance  :cry:
Offline luke
Re: Clutch problems
« Reply #6 on: 01 November 2012, 18:45 »
Garage at work sorted me out, new clutch cable as the ratchet had gone, and insurance renewal is 699 which is good news all around
Offline Thom89
Re: Clutch problems
« Reply #7 on: 01 November 2012, 21:08 »
Who you insured with Luke?
Thom
Offline luke
Re: Clutch problems
« Reply #8 on: 01 November 2012, 22:08 »
Thom
Renewed with admiral, I'm paying all upfront which is why it's as cheap as it is, fully comp with parents as named drivers plus I do around 5k mile a year to work and back
Offline Thom89
Re: Clutch problems
« Reply #9 on: 01 November 2012, 22:20 »
Thom
Thanks, my son is after insurance soon, we'll give them a try
Thom
