Author Topic: Engine replacement for mk5 gti (axx)  (Read 2776 times)
Offline BigRokx
« on: 25 October 2012, 23:27 »
Hi guys
The timing belt on my car, snapped whilst driving and as a result i now need a new engine  :angry:. Ive been searching for a replacement for ages now without any joy. I have found a couple recently though with the BWA code. Can i replace the engine block on with the BWA code keeping existing ancillaries or is that just not goin to work??? Any help would really be apreciated :smiley:
Offline bacillus
Re: Engine replacement for mk5 gti (axx)
« Reply #1 on: 26 October 2012, 22:52 »
afaik there shouldn't be a problem using a bwa engine to replace yours.
Be aware that the bwa engine uses a different rail pressure sensor to the aax one.
http://www.mk5golfgti.co.uk/forum/index.php/topic,43854.255.html
Without traction power is nothing!
Offline BigRokx
« Reply #2 on: 28 October 2012, 02:24 »
Cheers for that pal ill check the sensor issue out, aparently thrz also an ecu issue aswel n av been told it may need reprograming:-/
