Author Topic: Headlight light  (Read 1732 times)
Offline theviper
Headlight light
« on: 14 July 2005, 08:00 »
the little blue light on the dash dose not work no more  :cry: can i change the blue light or is it a new dash ???
thank's pete :evil:
Judderi
Re: Headlight light
« Reply #1 on: 14 July 2005, 08:25 »
Do you mean the blue light that comes on when you put main beam on?
Offline theviper
Re: Headlight light
« Reply #2 on: 14 July 2005, 08:29 »
yes that is the little bugger
pete :evil:
Judderi
Re: Headlight light
« Reply #3 on: 14 July 2005, 08:34 »
If your handy with a soldering iron you could unsolder it from the board and solder a new one in. Failing that you could swap the whole assembly if you can pick one up cheap. check ebay.
Offline theviper
Re: Headlight light
« Reply #4 on: 14 July 2005, 10:19 »
so the next question is were do i get a blue LED bulb from then ???
pete  :evil:
Offline Mr Blue
Re: Headlight light
« Reply #5 on: 14 July 2005, 10:31 »
www.ultraleds.co.uk
Might aswel replace all the bulbs for blue ones at this stage :tongue:
Offline theviper
Re: Headlight light
« Reply #6 on: 14 July 2005, 10:47 »
thanks for the help they are on the way to me now  :smiley:
pete :evil:
Offline Dizzie
  • Make friends with your fast
Re: Headlight light
« Reply #7 on: 14 July 2005, 15:15 »
dont' replace it with one from ultraleds. it'll blind you everytime you use the mainbeam!
there's no soldering involved. it isn't even a led. it's something different with a blue little cap on the top. Simple to change just pull the old one out and replace it.
Offline hockeylad72
Re: Headlight light
« Reply #8 on: 18 July 2005, 22:55 »
I'll second what dizzie says, no solering required purchased mine from local VAG dealership would also suggest replacing dash bulds at the same time
