Author Topic: PD130 Engine Swap  (Read 3209 times)
Offline dannyd126
PD130 Engine Swap
« on: 25 October 2012, 20:43 »
Hey guys
I have a mk4 SE tdi with the 110bhp engine.
it needs a new clutch but tbh id rather drop a PD130 lump in it, is anyone able to tell me what would need to be swapped to get it all running?
Obviously i would need the engine, ecu and gearbox, but does anything else need to be changed?
cheers
dan
A golf, Worlds finest
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: PD130 Engine Swap
« Reply #1 on: 25 October 2012, 21:15 »
IC, RAD, maybe air box, possibly gear linkages...possibly engine mounting points/engine mounts.
Don't know how many, if any, of the above are factual, just guesstimating  :smiley: :whistle:
Offline dan2252
« Reply #2 on: 25 October 2012, 21:59 »
Put a clutch in yours sell it buy a golf with pd130 as that will be cheapest way mate unless you want a project
MK4 golf 1.8 turbo agu :)
Offline EsSeX dAn
« Reply #3 on: 01 November 2012, 20:09 »
youll need the engine with clutch and flywheel. youd have to get a 6 speed box too as the clutch wont fit in your gearbox. youll need the pd130 driveshafts and need to adjust the power steering pipes slightly too.
youll also want the lift pump from the pd130 as well as the keys, clocks, ecu, turbo, boost pipe work,and some loom too. quite a lot of work for the sake of a clutch.
if you do go down the clutch route, change the flywheel too as these are prone to breaking. itd be a right pain to change the clutch only for the flywheel to die a few months later
i think i love you.....
