Author Topic: AGG crank sensor  (Read 2131 times)
Offline molegti
AGG crank sensor
« on: 24 October 2012, 13:53 »
Vaugely MK2 related. Where does the crank sensor on the AGG act on, is it the flywheel (like Fords) or something else attached to the crank?
Offline Diamond Hell
  • Opinions я Us
Re: AGG crank sensor
« Reply #1 on: 25 October 2012, 09:54 »
If it's like the ABF then it bolts into the block and there is a trigger wheel on the end of the crank.
Offline molegti
« Reply #2 on: 25 October 2012, 13:25 »
Thanks, I understand the sensor is the same part so that sounds like a fairly safe assumption.
Offline danny_p
« Reply #3 on: 25 October 2012, 22:47 »
trigger wheel is internal,  it is a 60 - 2 toothed wheel and it bolts onto the crank iself inside the engine.
looks like this,  piccy from an ABF  but cranck and trigger wheel are the same
all the VW's have gone bar 1.
Offline molegti
« Reply #4 on: 26 October 2012, 13:03 »
Brilliant - thanks
