Author Topic: help needed pls  (Read 1240 times)
Offline djmagpie
help needed pls
« on: 22 October 2012, 23:41 »
just fitted vr6 clutch .g60 flywheel and brakes over the moon and a cold feed air filter (ebay job ).. were do u mount the ignation amp as now the car has started missfireing wen boosting and i went on a 90mile trip on the weekend done about 60 miles and it loss a lot ov power and waz juddring like made and sounded like it waz running on 3 cylinder for about 20 mins then went bk to driveing ok but with the  missfire under boost again ive got a fault reader on order but havent got it at mo  any advise
1.8t agu,,Bora Vents,,Cai,,Vr6 clutch/G60 flywheel,,forge dump valve,,jom coilovers,,eibach front and rear arbs,, 15mm front 20mm rear spacers ,,3" downpipe & decat..sportex 4"oval exhaust
Offline Dalo Harkin
Re: help needed pls
« Reply #1 on: 23 October 2012, 12:49 »
if you have an ignition amp stick with the factory airbox and put a green cotton / K&N in it rather than a cold feed pipe
Offline djmagpie
Re: help needed pls
« Reply #2 on: 03 November 2012, 11:33 »
ive unpluged my ignition amp and pluged it back in and car running fine at mo is it faulty and need replacing ? got my scaner now plug it in and got a few fault codes 00515 ( camshaft position sensor) -- 16500 (engine coolent cercuit) -- 00285 (front right wheel speed sensor ) are these eazyish jobs to do and were can i got the parts from cheers
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: help needed pls
« Reply #3 on: 03 November 2012, 11:37 »
you need to clear the codes off and see what comes back. They might be years old
Also if the ignition amp is faulty it won't throw up a code
Offline djmagpie
Re: help needed pls
« Reply #4 on: 03 November 2012, 13:00 »
yeah i cleared the codes it had last nyt and thats the ones that came up 2day after a 20min drive ..so would u suggest buying a new ign amp ?? cheers
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: help needed pls
« Reply #5 on: 03 November 2012, 14:06 »
Not yet, sort the other codes first
camshaft position sensor looks easy enough, it's just on the drivers side front of the head
Coolant fault
 16500/P0116/000278 - Engine Coolant Temp. Sensor (G62): Implausible Signal
Possible Symptoms
    Starting the engine when engine is warmish or warm, idle rpm immediately is 1200 - 3000 rpm.
        Diesel: an indication is extreme long time burning time of the glow indication light.
    With all engine temperatures seldom idle rpm will vary between 900 - 1000 rpm.
    With engine warm (90 °C) the engine temperature suddenly drops (70 °C) and slowly comes back to 90 °C.
Possible Causes
    Wiring and/or connections faulty
    Engine Coolant Sensor (G62) faulty
Possible Solutions
    Check wiring and connections
    Replace Engine Coolant Sensor (G62)
Special Notes
In MY 1995-2002 (?) in Europe at VW-cars the G2/G62 had the bad reputation of breaking down often. The default G2/G62 is black and all replacements are green.
Check if the correct Coolant Fan Control Module/Relay is installed (check part number using parts catalogue)!
Speed sensor is easy enough to change too
Offline djmagpie
Re: help needed pls
« Reply #6 on: 03 November 2012, 15:06 »
thanks so much m8 ill get ordering some parts
