Author Topic: abf into a 6n  (Read 2632 times)
Offline mrsaunders
abf into a 6n
« on: 22 October 2012, 18:28 »
thinking of gettin a cheap polo and a donor 16v and starting a little project come spring, just trying to find info on a list of parts needed and if the power gains is worth all the hassle and money, not in a rush to do it just something to play around with when the weather starts warming up again so if anyone knows any info on this let me know
Offline tshirt2k
  • Been there...Done that...
Re: abf into a 6n
« Reply #1 on: 22 October 2012, 21:55 »
Unless you have good fabrication/ mechanical skill it may be a bit much to take on. Needs custom mounts s driveshafts for a start.
Mk3 ABF 16VT Megasquirt V3
Offline eamonnism
Re: abf into a 6n
« Reply #2 on: 22 October 2012, 22:35 »
Didn't the Ibiza gti have the abf lump? Basically a polo iirc. Should be doable.
Offline tweed
Re: abf into a 6n
« Reply #3 on: 22 October 2012, 22:38 »
 I thought the abf bloke was taller?
I wanted to do it when I smashed my abf but told not worth it.
Offline tshirt2k
Re: abf into a 6n
« Reply #4 on: 22 October 2012, 23:00 »
Anything is doable if you have the skill.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: abf into a 6n
« Reply #5 on: 22 October 2012, 23:01 »
Very true
Offline mrsaunders
Re: abf into a 6n
« Reply #6 on: 22 October 2012, 23:04 »
i have a cousin whos very good with a welder, from what ive found it takes alot of cutting/welding to make the engine fit but apparently the wiring side is really easy, def going to go over all my options carefully and not rush into it
Offline mrsaunders
Re: abf into a 6n
« Reply #7 on: 22 October 2012, 23:05 »
apparently the ibiza shares the front with the mk3 and not a polo, the 6n isnt as wide
Offline patryk92
Re: abf into a 6n
« Reply #8 on: 22 October 2012, 23:09 »
i was thinking about the same swap. i heard that you can fit the abf into polo using polo 1.9d engine mounts to avoid clearance issues, but dont know if its true
Offline mrsaunders
Re: abf into a 6n
« Reply #9 on: 22 October 2012, 23:10 »
yeah ive read similar but then also read this isnt the case, very confusing  :huh:
