Author Topic: Strange clicking/tapping noise while driving. *Fixed Laugh inside*  (Read 1615 times)
Offline Nino
EDIT: When I checked after work today 23/10/2012 I found that all 5 bolts where loose!! Tightened them up, problem fixed.
I noticed yesterday a strange clicking/tapping noise while driving, its as if there is something stuck to a wheel and everytime the wheel goes around it hitting the mudflap the noise isnt that noticeable when you speed up only when your at slow speed and I havent been able to hear it in reverse.
Now the only thing I have remotely done near any of the wheels is I have recently fitted mudflaps (the day before) and I have removed the rear wheels to fit them.
I have had a look around, nothing seems loose, and I cannot see anything on any of the wheels. the sounds appeares to be coming from the rear passenger side of the car?
Someone has suggested this could be my driveshaft?  :huh:
Any ideas would be a great help.
« Last Edit: 23 October 2012, 21:24 by Nino »
Current - MK6 GTi Edition 35
Offline Nino
Re: Strange clicking/tapping noise while driving.
« Reply #1 on: 22 October 2012, 11:24 »
I found this video, mine is similar to this but seems to be coming fromt he rear from what I can tell.
http://www.youtube.com/watch?v=P0-U9MkUZDs
The video seems to suggest CV joint?
Offline Chris#101
« Reply #2 on: 22 October 2012, 17:54 »
Unless you have a 4motion? And your sure the noise is coming from the back, it wont be a cv joint,driveshaft! However cv joints do.click at lowspeeds when there worn as ive just replaced mine
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Nino
« Reply #3 on: 22 October 2012, 20:08 »
It certainly seems like its coming from the backend of the car however I know sound can travel im so confused.
Offline harlemex
« Reply #4 on: 22 October 2012, 23:03 »
have you thoroughly checked the tyre? could be a stone or even a nail.
Offline Nino
« Reply #5 on: 22 October 2012, 23:24 »
Yep nothing :(
Offline Nino
« Reply #6 on: 23 October 2012, 09:59 »
Im going to remove the wheel when I get home from work tonight, Im getting really worried now the drive to work this morning was fine but that noise was concerning me, I find it strange how I do not hear it in reverse, and It defo sounds like its coming from the rear passenger side.
I find it strange how I never had this problem until I removed the rear wheels to fit my mudflaps....  :sad:
