Author Topic: Porsche carrera s 911 resurrection  (Read 6286 times)
Offline butler2.8i
« on: 21 October 2012, 21:59 »
This car had seen a few trips to the local hand car wash which had left the paint dull and covered in swirls, also a lot of TFR staining. The wheels nuts had also started to rust from the wheel cleaning acids that been used on them but the owner was getting these replaced when he gets the winter wheels fitted by the dealer at the end of the month.
Products and equipment used
Uber microfiber towels
Chemical guy’s woolly mammoth drying towel
3m yellow pads 150mm 75 mm
3m black pads 150mm 75mm
Halogen site lights
Makita rotary polisher
DA Polisher
Britemax Black max
Britemax Vantage wax
Carpro Fixer polish
Carpro eraser
Carpro Ironx
3m masking tape
Meguiars APC
Costco microfibre towels
Meguiars hyper dressing
Valet pro citrus bling
Valet Pro Bilberry wheel cleaner
Valet Pro PH neutral Snowfoam
Valet pro tyre dressing
AMDetails AMbubbles
Bilt Hamber clay bar
Autosmart Tardis
Various brushes
Kranzle pressure washer
Carpro Sheepskin wash mitt
Carpro Dlux
Noodle wash mitt
Carpro Lambs wool wash mitt
Poorboys microfibre clothes
Uber buffing clothes
Autobrite Snow foam gun
Chemical guys Jetseal 109
Autobrite Repel
Auto Finesse Mecury Metal Polish
00 grade wire wool
The wheels were cleaned using valet pro bilberry wheel cleaner before being given a hit of Carpro Ironx the was then given its first coat of snow foam whilst this was dwelling I went round the car using APC in a foaming head bottle cleaning the fuel filler area and various gaps and grills. The snowfoam was then blasted off with the pressure washer, and then the car was given another coat of the same mix snowfoam and the car was washed using the 2 bucket method with grit guards in both buckets and a Carpro lambswool wash mitt.
The car was then rinsed off using an open ended hose and I then went round the car with Tardis which was left to go to work before being wiped down with microfibre clothes. The car was then given a coat of Ironx again left to do its stuff before the car was washed down using the pressure washer.
The car was clayed using citrus bling and water mix (10 to 1) and a Bilt hamber soft clay bar which helped to pull more contaminates from the paint work it was then rewashed using the same method and dried using the woolly mammoth.
Outside cleaning shots
Some photos before I start
I then taped the car up and went round with various yellow 3m pads and Carpro Fixer polish, each panel was given a wipe down with Carpro eraser after polishing to check finish and remove any polishing oils.
I then went round the car using the DA and Britemax Black max and the black 3m pads which was buffed using Uber buffing towels.
 The car was given 2 coats of the Britemax Vantage wax leaving wax to bond for 60min and approx 60min between each coat again buffed using Uber buffing towels
The plastic trim was dressed using Carpro Dlux which is a cracking product which a little goes a long way and gives a stunning finish.
After this I cleaned the glass and gave them all 2 coats of Autobrite repel
The alloys and brake calipers were sealed using 2 coats of Chemical guys Jetseal 109 and dressed the tyres using the Valet pro tyre dressing.
Finished shots
Here’s a link to my facebook page
http://www.facebook.com/NorthEastCarCareUK
Offline Mr GTD
Re: Porsche carrera s 911 resurrection
« Reply #1 on: 23 October 2012, 22:14 »
Very nice work indeed... :cool:
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
« Reply #2 on: 23 October 2012, 22:31 »
Wow what a transformation  :cool:
Shame you're 4hrs away..
« Last Edit: 23 October 2012, 22:35 by Golf_GT_TDI »
Offline Khare
  • The bear that khares
« Reply #3 on: 24 October 2012, 19:38 »
This is great work. Mine really needs something like this. It's covered in swirl marks and light scratches from hedges.
How much does a detail like this cost?
Offline Mr GTD
« Reply #4 on: 25 October 2012, 21:13 »
There you go mate..Northeast car care
Offline Mr GTD
« Reply #5 on: 25 October 2012, 21:15 »
6hrs for me... :cry:
Offline bobbarley
  • I'm kind of a big deal...
« Reply #6 on: 25 October 2012, 21:49 »
That's going to be one happy owner!
Offline Khare
« Reply #7 on: 27 October 2012, 16:19 »
Ouch, 6 hours each way for me. Shame, because the price is very reasonable. If you were closer I'd definitely consider enhancement detailing soon.
Keep up the excellent work!
Offline DCmk3
« Reply #8 on: 27 October 2012, 17:11 »
18 hour flight from me..  :grin:
2014 Mk7 GTI - Littco L500
Offline Mr GTD
« Reply #9 on: 27 October 2012, 19:51 »
Lol can anyone beat this^^^^ :laugh:
