Author Topic: Anyone running a hydro clutch cable on a 20vt conversion  (Read 2202 times)
Offline Jimmyrallye
  • 20vt goodness
Have read countless threads and posts on this .. Ive got a mk3 gti abf box that im going to bolt on my engine got all the gear stick box clutch and flywheel ect .. Question is i know you need a seat actuator and a mk2 golf 1.3 clutch cable any one running this set up ? Thanks jimmy
Offline Diamond Hell
  • Opinions я Us
Re: Anyone running a hydro clutch cable on a 20vt conversion
« Reply #1 on: 22 October 2012, 13:09 »
I'm running the Seat actuator and the Toledo ABF cable on my Syncro.
You could fit a Corrado pedal box with the hydraulics if you wanted a 'kinder' pedal, or you were a girl.
Offline Jimmyrallye
  • 20vt goodness
« Reply #2 on: 22 October 2012, 14:44 »
Nah no pedal box change for me... How do you find that set up have you broke any clutch cables yet ? Also did you drill holes in bulk head for the cables ? Cheeeers dude :)
  • Opinions я Us
« Reply #3 on: 24 October 2012, 09:31 »
I have no concern about the Toledo cable, because it is OEM and routed in precisely the same course as it is on the Toledo, which is basically the same architecture as a Golf2.
Obviously this also means no cutting stuff, or b*ggering about.
It's the right solution, right down to the pedal, which, although I'm happy with on the track car, might be nice if it was lighter in a road car.
The hydraulic solution, using a Corrado pedal box and drilling a hole for the clutch master would resolve this concern.
Offline Jimmyrallye
  • 20vt goodness
« Reply #4 on: 24 October 2012, 14:20 »
Cool thanks for that.. :) well im fitting mine saturday ive bought a 1.3 mk2 cable clutch a few people have told me its all down to how you run the cable which you have described to a T .. Any tips on how to route the cable ... Thankyou ;)
  • Opinions я Us
« Reply #5 on: 24 October 2012, 21:55 »
Run it the same as the original one.
This is why you need the ABF Toledo/Ibiza one - it's designed for the front entry actuator, not the 1.3 one, which is designed for the vertical entry actuation of the 020 or 085 'box.
Offline Jimmyrallye
  • 20vt goodness
« Reply #6 on: 24 October 2012, 22:08 »
Hmmmmmm bummer id rather run it oem like it wos designed is the seat/toledo one self adjustment ? What year is the above cable 1998 ? Thanks pal
  • Opinions я Us
« Reply #7 on: 25 October 2012, 07:52 »
Part numbers from your SEAT dealer should be:
Toledo ABF clutch cable 1LO 721 335G Yes it is self-adjusting.
Lever arm actuator assembly 02A 141 708B.
The last part of the jigsaw for cable actuation is the bracket to hold the cable in position. Can't find that part number right now.
